Thread: 2.8KB + TF heads = no fit....
12-15-2009 12:45 AM #1
Ok, so i had posted this in my build thread over on mustangforums and i thought i would share it as well with you guy in case you are going the same route i am...
"Copy and paste"
Update: So Ryan and myself worked on the motor this weekend and ran into all sorts of issues
Basically the 2.8H doesnt seat right on the TF heads... :(
The heads prevent the blower manifold from sitting all the way down in the valley of the motor like it should.
Anyway, so here is what we did Sat.
Bagged and taped the motor in preparation to grind off knock sensor mounts
took the cutting wheel and cut most of the mounts off
test fit the blower and the sensor mounts are still too high...
rebagged and tapped and took a grinder to the rest of the mount...
we then test fit the blower and found out the "head supports?" were in the way...
We then measured and marked these for cutting and bagged and taped the heads... anyone notice a pattern...
Notched the supports
KENNE BELL 2.1L - SOLD
KENNE BELL 2.8H - AWAITING INSTALL
12-15-2009 12:46 AM #2
At this point i'm getting happy cuz we are about to finally get the blower on top of the motor and it will actually fit right!!!
So we yet again lift the heavy ass blower on top of the motor for one more test fit...
wait... whats that.... let me get a closer look...
F#CK ME!!!!!!!! story of my life.....
here are some more pics
(driver side)
(area where it is contacting the driver side head)
(Passenger side)
(area where it is contacting the passenger side head)
so we stopped there to say the least. Pretty mad Sat night.
Called Nick @ modular head shop and he is supposed to be checking the coolant port thickness and if all is good, back to the cutting wheel and we will shave some material from the front areas of the head to make the blower fit right... I cant believe this @#$%...
anyway, here ore some pics of the blower on top of the motor for you guys...
(place valve cover on head just to see what it will look like)
Thats all i have for now.. basically we accomplished nothing this weekend as far as bolting everything together. Waiting on word from Nick and we shall see what the next step will be..
12-15-2009 01:02 AM #3Senior Member
- Join Date
- Sep 2008
- Posts
- 618
OMG once you get everything worked out that thing is going to be a absolute BEAST. I look forward to your dyno sheet.
12-15-2009 01:04 AM #4Senior Member
- Join Date
- May 2009
- Location
- mn
- Posts
- 286
aftermarket parts.... :(
Modern Automotive Performance
Custom built twin turbo 2V
12-15-2009 01:11 AM #5
man that really sucks, but will be a beast if you get it running
Hellion 03 GT
DSS shortblock/ported heads.......531whp/630wtq @10.8psi
94 Integra LS "stock dd".....142hp
12-15-2009 02:46 AM #6
dude the 2.8H looks so fucn huge!!! does that fit under a stock hood? i wish that the TF hads were out whn i had bought my pp pi heads!! but sht happens oh well:(
Good luck man. thts why i luv Centri blowers!!Built stroker motor, comp cams,MHS 0 cam gears, full suspension, built rear, cobra brakes and wheels. just need some BOOST!!!!!
12-15-2009 08:02 AM #7
I just put a drill bit into that spot and you have a mininum of 1/4" to work with. Looking at the pictures I drilled directly underneath the flange overhang where it would/should be the thinnest. My measurement does not include taking the flange overhang off so you can cut it flush to the head and start there for fitment, then you have another ~1/4" of aluminum to work with.
IMHO - It looks totally safe to cut away what you have marked in black there.96 Bipolar GT
12-15-2009 08:34 AM #8
LOL! Thanks and me too. Should make 600+rw
yea i hear ya.... I didnt think i would have this many problems though...
Thanks
LOL no, it wont fit under a stock hood. You would have to see this thing in person... Its crazy how big it really is...
You the man Nick!! I will send you some pics this weekend if i get around to working on the motor so you can post themm on ur site for customer reference.
Thanks again Nick!
Bookmarks
