Quote:
Originally Posted by Brian W.
i was pretty sure that all 4v were the same outside dimensions. but what about the blocks... are the all the same externally(3v and 4v)?
did you just get an aluminator long block and bolt the 3v accessories to it then?
The 4.6's are a short deck, the 5.4's are a taller/ wider long deck. The heads, be it 3v or 4v are essentially the same size for the 4.6's and 5.4's, however the intake manifolds are wider for the 5.4's. the 5.4's are also slightly taller and wider.
