Go Back   ModularFords.com > Modular > 2005 - 2010 Mustang GT
Reply
Old 11-02-2009, 07:52 PM   #25
S1972005
Status: Senior Member
Long tubes definately helped my car. It has to be in the tune somewhere. If headers made no difference, so many people wouldn't have them. Not trying to be a pain,just keep looking and at least consider a GREAT dyno shop with a GREAT tuner, not merely a dyno operator.
__________________
Procharged 2005 GT, Stage 2 Comp blower cams, JBA headers, charge motion deletes, 3.73s, trutrack, PI t/c, QA1 adj.s on all 4 corners, ucas,lcas, BMR anti roll and panhard bar, front sway bar delete, ect. 7.33@96 1/8, & 11.45@119 1/4
S1972005 is online now   Reply With Quote
Old 11-02-2009, 08:00 PM   #26
38stang
Status: Junior Member
I picked up .3 in the 1/4 mile with JBA long tubes and no retune.
__________________
05 Mustang GT
steeda tri-ax shifter, JBA LT's, O/R H-pipe, roush muflers, SCT tuner
96 Mustang V6
4.2L single port, SSX sheet metal intake, SSM stage 3 heads , 225/230 .545/.545 lift, 1.7 RR, Procharger 14psi, 60LB injectors, 255LPH fuel pump, SCT 2400 MAF blow through, SCT chip, stallion 3000 stall, B&M shift kit, 3.73 gears, T-lok, flowmasters, LT's
38stang is offline   Reply With Quote
Old 11-02-2009, 09:05 PM   #27
black2003cobra
black2003cobra's Avatar
Status: Administrator
02GTP - Unfortunately, I don't have the software to help you with the cam timing question. Sorry again! (I'm batting zero here.)
black2003cobra is offline   Reply With Quote
Old 11-03-2009, 08:46 PM   #28
Balli
Status: Member
+1 on that as well. I had similar results on my Mustang. Before longtubes I ran a consistent 13.2 at 102. After JBA longtubes, I ran a consistent 12.9 at 105 mph.
Quote:
__________________
Mods:
JLT2 Intake
IMRC Delete
E85 tune from VMP.
311 rwhp (Uncorrected)
328 rwtq (Uncorrected)
Balli is offline   Reply With Quote
Old 11-03-2009, 09:20 PM   #29
02GTP
yea i bet that was with an off road mid pipe at the same time. thats what everyone says "i gained XX wheel and cut my time by XX sec with just headers." but they all fail to mention that was going from a stock exhaust to LT's/off road mid. 95% of that gain was from deleting the cats. ive seen your story 100 times and its been the same thing every time.
02GTP is offline   Reply With Quote
Old 11-03-2009, 09:31 PM   #30
S1972005
People have been putting LTs on hot rods for decades. It helps. At least consider a dyno tune. Nobody on here is going to gain from this except mayby you. Almost everyone on here is simply trying to share their experiences and expenses. I speak for myself and everyone I know when I say Long Tubes and a dyno tune helped our cars. Good luck.
__________________
Old 11-03-2009, 09:49 PM   #31
Balli
Status: Member
I went from stock manifolds and cats to long tubes and hi flow cats. I can tell you off the bottle I picked up about 12 wrhp. On the bottle it was a consistent 30 rwhp on the same 100 shot. TQ jumped from 478 to 508. That too was consistent on the same 100 shot. I went with the JBA's because they seemed to show the greatest gain in TQ. I know every header is different and make power at different levels. I have no experience with the pypes headers. All I know about them is that they are made in China.
Quote:
__________________
Mods:
JLT2 Intake
IMRC Delete
E85 tune from VMP.
Old 11-03-2009, 10:10 PM   #32
02GTP
yea i get that, but factory exhaust has changed a bit since the 60's. its not the same today. and didnt JBA's make the least amound of hp on that MM&FF test?
Reply
Bookmarks
Thread Tools
Display Modes Rate This Thread
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
American Racing Headers Blow-By Racing BMR Fabrication Campbell Automotive D'Agostino Racing Diablosport Dynojet Research Edelbrock Evolution Performance Forced Air Performance Fore Precision Works Granatelli Motorsports Holcomb Motorsports HP Tuners J&M / Hot Part Kenne Bell Lethal Performance Lightning Force Performance Livernois Motorsports M&H Tires Metco Motorsports Ninosport Mustang Parts Powerhouse Racing and Performance PSI Motorsports Saleen Techco
Powered by vBulletin® Version 3.7.1
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Brooks Speed Inc. / ModularFords.com © 2002 - 2009
