Go Back   ModularFords.com > Modular > 2003 - 2004 Mustang Cobra
Reply
Old 03-08-2008, 06:45 PM   #1
jeffs
Status: Senior Member
Default Clutch Guru's Step Into My Office Please!!
I've got a Spec 3+ coming with a 26 spline input upgrade. I don't plan on replacing my flywheel with a Fidanza like I see so many people doing, I plan on resurfacing my stocker if it looks to be in decent shape. Why do people spend the extra money on flywheels with their new clutches if their existing one is in good shape? Also, I plan on doing the install myself and have read posts where results have been poor due to the installation, I don't get what could get messed up with such a simple task, but please inform me if there's a special reason I should pay a professional to do work that I feel I can do. Just to let you know, I plan on farming out the flywheel resurface and the 26 spline input into the trans install, I'm just going to bolt the stuff together on my car, I HOPE!!!
__________________
04 screaming yellow Cobra, Mac cai, Accufab inlet and TB, Steggy stage 4 port w/2.93 upper/4# lower, BBK longtubes and catted X-pipe, Magnaflow Catback. MM full length subframe connectors, MGW shifter,
Spec 3+/Liberty 26 spline input shaft. Let's run'em!
jeffs is offline   Reply With Quote
Old 03-08-2008, 06:56 PM   #2
04svtsnake
04svtsnake's Avatar
Default Re: Clutch Guru's Step Into My Office Please!!
The nice thing about the Fidanza clutch is it has a removable friction plate on it. So on down the road when you change the clutch again for whatever reason, all you need to do is buy a new friction plate instead of machining the flywheel. Also the stocker can only be resurfaced once before to much material is taken off. Here's a good video for installing a Spec 3+, step by step, by the guys from DDDdirectory. Maybe it'll help ya out.
http://videos.streetfire.net/video/a...2600b9a04b.htm
http://videos.streetfire.net/video/3...2600ba01a0.htm
__________________
MY CAR IS FOR SALE! $16,000 http://www.modularfords.com/forums/s...d.php?t=121713
Redfire 2004 Cobra, born Feb 17, 2004. Whipple W140AX,
http://www.myspace.com/tony_alleman
Proud Member of the Mid-Atlantic Cobra Association
04svtsnake is offline   Reply With Quote
Old 03-08-2008, 07:24 PM   #3
jeffs
Thanks 04 SVTsnake, that's very helpful.
__________________
Old 03-09-2008, 08:33 PM   #4
Dana
Dana's Avatar
Status: Bluesmobile
According to one of the clutch manufacturers, the stock FW can flex under the stress/load of an aftermarket pressure plate.
I would replace the stock FW with a Fidanza.
Dan
__________________
'03 Redfire Coupe 6 spd 10.54@133.5
Whipple tuned by HBH, BilletFlow stuff (and Doug didn't even ask me to post that), Raptor Shift Light, Solid Axle w/3.73, etc, etc, etc...
Dana is offline   Reply With Quote
Old 03-10-2008, 03:03 AM   #5
TurboShortBus
TurboShortBus's Avatar
Send a message via AIM to TurboShortBus Send a message via Yahoo to TurboShortBus
Quote:
While that statement MIGHT have some merit (although I find it a little difficult to believe, unless you're using one hell of a legbreaker clutch), beware of somebody just wanting to sell you a flywheel. There is a lot of BS and misinformation flying around from product vendors these days.
Mark
__________________
1994 GT convertible with 2004 Cobra engine, distributor drive conversion, and AEM # 1401 EMS.
2004 GT # 26 for NASA TTD
Get some skills and go road racing. Use the brakes, steering, and gas for a change. Besides, you paid for all 3.
Some people work on cars. Others work on fancy signature graphics. Which one are you?
TurboShortBus is offline   Reply With Quote
Old 03-10-2008, 09:19 AM   #6
Dana
Dana's Avatar
Status: Bluesmobile
Quote:
Mark
Ya, it is a little hard to believe, but I thought I would pass it along anyway because it wouldn't take much distortion to screw up an otherwise perfect clutch install.
__________________
Reply
Bookmarks
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
