Go Back   ModularFords.com > Modular > 2005 - 2010 Mustang GT
Reply
Old 06-23-2008, 11:50 PM   #9
Shifty
Shifty's Avatar
Status: Senior Member
Quote:
Originally Posted by retfr8flyr View Post
Everyone is going to recommend the kit they chose, including me, so you will get biased recommendations. I think the 2 best kits available are the TurboHorsepower and the PowerHouse. Mike at Powerhouse has done extensive tuning on his kit so if you don't have someone available to do a custom tune I would lean toward the Powerhouse kit. The Turbohorsepower is a little more custom and Jim will configure the kit to your specfic needs or use the standard kit if that is all you require. I don't know how good Jim's tune is. compared to Powerhouse, so I would recommend getting a custom tune with the THP kit. You really can't go wrong with either kit.
Earl
Couldn't have said it better myself......really.....I couldn't have.
__________________
If I'm ignoring you for some reason it's because you've made my ignore list. Congrats.
“A turbo: exhaust gasses go into the turbocharger and spin it, witchcraft happens and you go faster.”
2005 Mustang GT
Bullseye S480R Turbo
It's slow
Shifty is offline   Reply With Quote
Old 06-24-2008, 01:12 AM   #10
androdz
Status: Banned
You are right retro but You forgot to add Hp Performance my base intercooler is bigger than the upgraded intercooler ;). Either way I would had done an intercooler delete and bought a precision one.
Andrew
androdz is offline   Reply With Quote
Old 06-24-2008, 09:45 AM   #11
TurboPete
TurboPete's Avatar
Quote:
Originally Posted by Al Guapo View Post
+1 That's the only reason why I didn't go with the Hellion. An important consideration if you're going to lower your car. Everything else seemed good about it though.
My vote? Power House all the way
Everyone is quick to point out the plumbing underneath the k-member, its even with the tires so as the tires go up so does the car and the clearance. My car sits pretty low and I have had no problems with the plumbing , in fact the plumbing that does scrape speed bumps is the mid pipe. No different then when you go with longtubes.
Im not sure why people feel that my car doesn't whistle thats not true , you can hear the Turbo spool very easily.
But like mentioned before people are going to pick and choose which ever the feel is better.
All I can say is My Hellion Kit fits perfectly from the beginning, unlike some of the other kits that most people have had to modify slightly to get them to fit right, which is understandable in my opinion with anything that is not factory.
The draw thru set up works just fine , while many other kits have had to re-design there pipeing to smooth out the MAF signal do to different size plumbing and location.
Again there have been modification to correct these issues .
I like the fact that my kit is all stainless hot and cold, I sent my kit to ceramic coat as well.
Not all the kits available out there use stainless, some use mild steel Jet Hot coated .
Again this still works fine.
Just do your research and by the kit that makes you feel comfortable.
Pete
__________________
2007 Hellion Turbo Stang,Precision 78mm Powered!
ATF 4R70W Stage 4 Tranny, PI Converter, Lethal Return Fuel Sytem, Steeda Adjustable Drag Suspension.C&L Intake , Stock Heads & Cam.
TurboPete is offline   Reply With Quote
Old 06-24-2008, 12:28 PM   #12
lito
lito's Avatar
Pete
I'm glad you like it, there is nothing better than enjoying what we buy, but in the case of the piping I do not like it and yes I've seen them, we had three cars with this kit installed, one even has the bigger piping option and is incredibly low, yes you won't scrap it on speed bumps but if you, by any chance get a rock or an uneven sewer or whatever on the road you can kiss you pipes goodbye. The clearance in the bigger version is just ridiculous, we had them modified and made the pipes flatter and wider and relocated so they will be closer to the k-member to gain some clearance there. If your car is a basically a track car or your roads are good enough that you have a better chance on getting struck by a thunder than getting something on them that can ruin the pipes then do it, down here it is an absolute no-no.
Regarding the sound, it is just a matter of taste, some will like the stealth condition of the Hellion some will just prefer to make noise, What I'm sure of is that Hellion does not sound like this:
http://www.youtube.com/watch?v=2EHkAtVsMe8
I'm not judging people for their tastes, just noting what it does and what it does not do, hey if people is spending 800$ and almost 400$ in installation on the hotrod cams just for the sound. Maybe this thing is important, personally I like the sound of the BOV.
And on the draw thru thing, I'm not a tuner, I'm just repeating what I've heard, as I said before, one of the Hellion cars has not been tuned just yet but with the paxton tune it had is running pretty fine, I was expecting otherwise.
I have nothing against the Hellion kit, I'm just pointing the things I do not like of it so people can make a wiser decision, I made mine, but it is just me. I got to say their kit is great, is almost always in stock and if you don't want to get too complicated you can get one from Brenspeed with everything you need including the tune (I forgot we did just that with a customer from another part of the country and he can't be happier).
lito is offline   Reply With Quote
Old 06-24-2008, 12:54 PM   #13
TurboPete
TurboPete's Avatar
Quote:
Originally Posted by lito View Post
I'm glad you like it, there is nothing better than enjoying what we buy, but in the case of the piping I do not like it yes I've seen them, we had two cars with this kit installed, one even has the bigger piping option and is incredibly low, yes you won't scrap it on speed bumps but if you, by any chance get a rock or an uneven sewer or whatever on the road you can kiss you pipes goodbye. The clearance in the bigger version is just ridiculous, we had them modified and made the pipes flatter and wider and relocated so they will be closer to the k-member to gain some clearance there. If your car is a basically a track car or your roads are good enough that you have a better chance on getting struck by a thunder than getting something on them that can ruin the pipes then do it, here it is an absolute no-no.
And on the draw thru thing, I'm not a tuner, I'm just repeating what I've heard, as I said, one of the Hellion cars has not been tuned just yet but with the paxton tune it had is running pretty fine, I was expecting otherwise.
I has nothing against the Hellion kit, I'm just pointing the things I do not like of it so people can make a wiser decision, I made mine, but it is just me. I got to say their kit is great, is almost always in stock and if you don't want to get too complicated you can get one from Brenspeed with everything you need including the tune (I forgot we did just that with a customer from another part of the country and he can't be happier).
I would have to agree with you on some points. The streets here in Miami are very good, thats why I guess I cant complain. I dont drive my car as much as before because I dont want to put alot of miles on it . I drive it mostly on the weekends and I have a Accord for dd for work .
I thought you were talking about Turbo whistle not the blow off. Then again my car is auto , and Im not blowing to the atmoshere. Like the Blow thru meters .
I also have the race pipe options .
Like I said previously pick one your happy with , they all make power.
Pete
__________________
Old 06-24-2008, 08:44 PM   #14
daniels2005
you can hear my bov on this 10-140+mph datalogging run
http://www.youtube.com/watch?v=oIgXL1RBjUw
this is with the WG plumbed back into the exhaust so the car is pretty quiet compared to a open WG.
__________________
Cris
_____________
2005 Mustang GT 5spd, Spec Stage 3, Custom 60mm Turbo Kit, Alum Driveshaft, SCT, BMR, Steeda, Powerslot, Hawk, CMRC deletes, Autometer, Greddy, Innovate, MGW, JGS Turbo, TiAL, MSD COP
daniels2005 is offline   Reply With Quote
Old 06-24-2008, 09:11 PM   #15
androdz
Status: Banned
nice vid daniels but preferably I love lito's video hehe. Quiet turbo's for some reason just sound make the car sound slower lol. Just look at this one doesn't look that fast but sounds like if it has 600hp lol.
http://videos.streetfire.net/video/6...5-GT_73920.htm
Andrew
Old 06-24-2008, 09:25 PM   #16
lito
lito's Avatar
Andrew, that is not my car, mine is still NA and I really gonna miss that sound (check sig), but now, totally off topic, why people that record videos stops pushing their cars once they reach the camera man?? they are leaving the nicest parts out! In this turbo videos it is more understandable because you can hear the turbo whine mostly with an oncoming car but leaving the part that the car goes away takes an important part of it too.
Reply
Bookmarks
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
