Quote:
Originally Posted by NOLAGT
Now those sound nice. Are those borals in the first vid? Do you know what else is done to the exhaust?
Those are Pypes violaters mufflers with JBA L/T and off road h-pipe.
Quote:
Originally Posted by tom281
Even though you lost some boost PSI, how did the HP/TQ respond? I could see it possibly gaining HP up top even though boost was down a little due to the increased flow. Just curious, thanks.
At first it lost about 12 hp down low but picked up 14 on the top so overall in the hp department is was about a loss. I do not remeber exact but i belive the torque did the same thing.
After the cam install we did do a 10% overdrive on the crank which brought all the power back plus a little but then again we thru another 2-3 lbs of boost at it which does not make it exactly fair for comparison.
Sorry i do not have more exact data but if you are going to run a blower with cams i would recomend going with Comp Cams blower profile.
