Go Back   ModularFords.com > General Discussion Forums > Mustang Pictures
Mustang Pictures Share your best Mustang pictures and videos here.
Reply
Old 10-23-2008, 10:35 PM   #1
Speeds8erM-1
Status: Senior Member
Default Track rental vid! JimFitz, Cobras, LS1's
Higher Quality Youtube Link
YouTube - MMP 1/4 Mile Rental 2008
Streetfire
MMP 1/4 Mile Track Rental 2008- Video
Black GT pulling the tires w/ the sheetmetal wing is JimFitz's MPH Built 2v car with a KB 2.8 (@ 27 psi I think) & a small shot
Silver Notch is a Dart 347/TFS High Ports/Twin T66 Turbo Car, TH400 Trans, ran the 8.91@155 on pump gas/meth and low boost (15 psi), he put the C16 in it and turned the boost up and all it did was spin at half track, went 157-158 MPH on another pass though
Silver LX Hatch is a Mexican Block 331, AFR 205's, HP T66 @ 15 PSI, TH400, Pump Gas/Methanol car, went a best of 9.66@138
Red SS is a TFS LS6 Heads, Custom Grind Cam, Fast 90mm, forged 347, 6 Speed Car, taking it easy on the 10 bolt he ran an 11.69@124, all motor, only a 1.94 60 ft
Trailblazer SS is Heads & Cam, stock bottom end, Yank 3600 Stall, 20" Nitto DR's,
The Pro Mod is an 864 cubes, 3 stage nitrous, Semi Hemi setup, has been 3.90's in the 1/8
Black C5 Z06 is a HCI, forged 347, 100 shot
Red C6 is an APS TT car, dunno what else is done to it, went a 9.7@151 earlier in the day!
Speeds8erM-1 is offline   Reply With Quote
Old 10-24-2008, 08:04 PM   #2
stangfreak
stangfreak's Avatar
that video was mint.
what did the mach 1 have?
__________________
2003 whipplecharged cobra
MODULARFORDS ADDICT. BEST SITE
http://www.dagostinoracing.com/
stangfreak is offline   Reply With Quote
Old 10-24-2008, 08:22 PM   #3
jimfitzgerald
Status: Banned
Thanks for posting that. Mine is the first and last pass, not counting the "in-car" video.
jimfitzgerald is offline   Reply With Quote
Old 10-24-2008, 09:17 PM   #4
stangfreak
stangfreak's Avatar
jim were you running 27lbs and nitrous?
__________________
Old 10-24-2008, 10:33 PM   #5
jimfitzgerald
Status: Banned
Quote:
I made 4 passes, one with no nitrous, two with 50 shot off the line, and two with 50 shot in 3rd gear only. I didn't check the blower psi, but it should have been 27 or close to it. It was not a new belt, so boost could have been down a little.
Old 10-25-2008, 09:05 AM   #6
Speeds8erM-1
Procharger P1SC @ 10 PSI, a bunch of suspension stuff, tubular k member. He went a best of 10.87 that day
Old 10-25-2008, 03:35 PM   #7
jimfitzgerald
Status: Banned
Well, evidently I was not spraying on the first three passes. We just found out my throttle linkage was bent and the WOT switch was not on. On the last pass I sprayed in 3rd gear using a push button on the steering wheel that bypasses the WOT switch and arming switch. That's the pass where I ran 9.275 @ 150.22. Hopefully tomorrow, we'll go faster spraying off the line.
Reply
Bookmarks
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
