Go Back   ModularFords.com > Modular > 2005 - 2010 Mustang GT
Reply
Old 12-10-2008, 02:07 AM   #33
psfracer
psfracer's Avatar
Status: Whippled!
Quote:
Originally Posted by TexStang View Post
The new Roush TVS setup looks to be promising, especially with some of the times guys on here have been turning with it and the stock motor. I was wanting to get some thoughts on how it compares to the whipple 2.3. It seems that the TVS setup is a newcomer to a game that the whipple has already been in. What I'm wondering is how do you think the TVS would/will compare to the Whipple at higher boost levels, say 15+ psi? I already realize that both work well on the stock motor, but I'm wanting to get some thoughts on which one y'all think is the better huffer at high boost levels? Thanks
Reasoning? I'm not disagreeing at all I just want some details. It'd be nice to be able to compare some cars with whipples at 15-16lbs to cars with the TVS at 15-16lbs and see how they compare, and maybe a bit higher, say around 18-20lbs
Ok, I can help you out here as I have a 2.3 whipple @ 16psi. AND, as luck would have it, I just installed some interceptor gauges and drove 174 miles to the track in Barona this last weekend to race on Saturday and Sunday.
So, as far as the 2.3 whipple goes, this is the facts:
I have 577 rwhp and 519rwtq---this last weekend my best et was a 6.685 @ 101.96mph in the 1/8th, which is about an 10.4X in the 1/4. I have actually ran a 10.67 in the 1/4 but that was with only a 6.81 1/8th mile ET.
This is with 281cid, stock heads, stock cams, and the 5R55S trans with a PI 3300 stall and 4.10s
The IATs on the drive down to San Diego were typically between 104 to 124 degrees. I was traveling the usual 75 mph and it was about 65 degrees outside. Coolant temp leveled off at 195 and stayed between 190-195. Trans temp leveled off at 175 and stayed pretty constant.
At the track, by adding ice into the water tank (I have in the trunk) the IATs would drop to about 82 degrees, and at the end of the run be 96 degrees.
With the 2.3 whipple, anything higher then 12 psi you will need a larger throttle body. I went with the black diamond as I am running 16psi.
If your interested on how it runs, take a look: http://videos.streetfire.net/video/S...rag_204198.htm
So that is some unbiased info on the 2.3 whipple. Now, hopefully there is someone out there that has the TVS at 16 psi that has done some datalogging that can post the same info.
__________________
2005 GT Auto Whipple @ 18psi - 604 rwhp 543 rwtq
1/8th - 6.491 @ 106.37 - 1.424 60'
1/4 - 10.138 @ 132.39 - 1.445 60'
psfracer
psfracer is offline   Reply With Quote
Old 12-10-2008, 01:09 PM   #34
HotRodHarry
HotRodHarry's Avatar
Status: Moderator
Send a message via AIM to HotRodHarry
I dont know why they dont. I am guessing they just dont have the drag race testing that JDM has. Thats the key here. Lots of Real world Drag Racing with his test cars.
I think I may have the fastest stock motored/trans/converter/suspension(as in control arms/swaybar)/full weight S197 out there.
For some reason these Saleen Superchargers really make the right hp/torque numbers to get these cars down the track. And like you said...www.TeamJDM.com has the knowledge to get them there with 13 lbs of boost only.
__________________
07 GT
10.73 1/4 at 128 mph 1.58 short time
6.88 1/8 at 101 mph
Saleen 13 lbs boost
Stock motor/trans/rear
My 1/4 mile video below
http://www.youtube.com/watch?v=TKrB5TGe15Q
Tuned by TeamJDM.com
www.HOTRODHARRYS.COM
HotRodHarry is offline   Reply With Quote
Old 12-10-2008, 01:11 PM   #35
HotRodHarry
Status: Moderator
Quote:
I know Nitrous Pete did alot of datalogging....maybe if he has some time he will see this post.
Thanks for the info....
__________________
07 GT
6.88 1/8 at 101 mph
Saleen 13 lbs boost
Old 12-10-2008, 01:43 PM   #36
TexStang
Status: Senior Member
Send a message via AIM to TexStang
Thanks Paul, I've kept up with your car alot over on s197forum, it hauls balls for sure. Thats impressive times for basically just a built bottom end. The info you posted is more of what we need to compare different setups. Info on strictly race cars doesn't help alot, but on a car that sees plenty of miles, thats whats important. I was hoping someone would post up with info almost exactly like you posted, i.e. how a blower setup works at a higher boost in real world, dd-status. Thanks!
Hopefully he will. Does he ever DD the car? As in trips longer than just to the grocery store etc? This thread has already been of good use to me and I hope it helps some others out down the road.
I'm wanting to see how these two setups compare, most importantly in DD-status, 2ndly track times, and 3rd trap speeds. Looks like we're on the right path, just need more people with the TVS and whipple to post up
__________________
Cory
06 GT, a few bolt ons
TexStang is offline   Reply With Quote
Old 12-10-2008, 10:00 PM   #37
nitrous pete
nitrous pete's Avatar
Send a message via AIM to nitrous pete
I can say this in much less words, Roush Pla Bangg..POWER.
My air trmp driving 80mph for 1/2hr in 48% amb. cooler temp 68 % Now I have been data loging for 18years. Thats efficient...... 14lbs Stock all motor sus. Ect. 10.57 131 mph. NO TRICKS HERE.. As Paul and Harry both Saw No Nos !! Peace Roush All the way , OHHHH When you call you talk to someone,,, That means a lot to me
Sorry forgot Its all in the tune :) Super tuner Nitro OUT !
__________________
Nitrous petes
2003 SVT Cobra
Eaton Blower - 589RWHP & 665TQ
Eaton Blower w/nitrous - 788RWHP
Kenne Belle Blower - 728RWHP & 705TQ
1st 03 cobra in the 9sec.
08 GT Auto Et 10.57 @ 131, Roush TVS
2300 Blower, Stock motor.
East coast Super Tuner diablosport
Cx609 290 8513 Tuned.ahh Since the 80's
NMCA Record holder 8.64 @ 161 1996
609-290-8513 nitrouspete@gmail.com
More to come
nitrous pete is offline   Reply With Quote
Old 12-10-2008, 11:01 PM   #38
Stang925
Stang925's Avatar
Status: Member
I say whipple all the way.
Stang925 is offline   Reply With Quote
Old 12-10-2008, 11:40 PM   #39
HotRodHarry
Status: Moderator
Well..to be honest...there are way more stock motored Roush TVS and Roush supercharged S197 stangs out there than Whipple. I mean, like I said...the Whipple makes some great power...but most can not turn great 1/4 mile times. Yes, we have one here now that does...but he does have work done to his car and is pushing some boost. Not knocking it...still awesome setup and my congrats for getting that car rippin!
__________________
07 GT
6.88 1/8 at 101 mph
Saleen 13 lbs boost
Old 12-13-2008, 12:28 AM   #40
CataclysmGT
If you want to truly compare superchargers, someone needs to bench flow them in the same conditions, on the same machine. HP numbers, track times etc all add to many variables.
__________________
Its got some stuff done to it.......
CataclysmGT is offline   Reply With Quote
Reply
Bookmarks
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
