This is a custom inlet for a 2v 2.1L KB that I've designed and built. The inlet accepts the 03-04 cobra TB and free's up the restriction the factory inlet had. My car made 585hp/569tq on a mustang dyno and 607/575 on a dynojet. This was achieved at 20lbs boost (yes 20lbs on a 2.1L) with 18* timing and iats between 125-130*. The car made power all the way to redline which is set at 6700rpm on my car. My engine mods: 298cid stroker 8.5/1CR, ported heads, MPH blower cams, Accufab big oval TB and my custom inlet. The inlet uses the cobra TB and cruise cable and DOES fit under a stock GT hood. The inlet also retains the EGR so you wont have any issues with emissions. Also included is an intake tube that goes from the TB to the MAF along with couplings and T-bolt clamps, so you can use your cold air kit. The couplings supplied will NOT work with the factory MAF, 90mm is required. There is no custom work that needs to be done to make the inlet work, just bolt it in and go. Retail price will be set at $795+ shipping. As a promo I am selling the first 4 for $700 shipped. If you have any questions feel free to PM me or call at 916-276-0969. I am located in Seattle, WA. Here's a link to a vid of my car. Dyno pulls at the end of video.
David
http://videos.streetfire.net/video/2...-KB_640147.htm
