Go Back   ModularFords.com > Modular > 2005 - 2010 Mustang GT
Reply
Old 09-05-2009, 05:44 PM   #1
udelose
udelose's Avatar
Status: Senior Member
Default Engine Failure... Again...
Well I just get back from the tuners. Ran great for three days. I fill her up with gas and leave the station. Never get into boost and loose a cylindar.
Start taking apart today and this is what I find... 0 compression on #2 drivers side bank...
Exhaust Valve slipped off the follower and bent clean over... Doesnt make sense...
I dont know what would cause this especally after 30+ runs on the dyno and multiple wot's for two days in a row... and 400+ miles...
This stuff is just dissheartening...
__________________
Black 05 Stang
Current Mods: ProLine Shortblock, MMR stg2 heads, MMR stg2 turbo cams, TurboHorsepower Twin Turbo,
Numbers: 15psi, 17* timing, 722rwhp 689rwtq on a Mustang Dyno
Tuner: Frank Soldridge PSI Motorsports Inc.
udelose is offline   Reply With Quote
Old 09-05-2009, 06:21 PM   #2
05stroker
05stroker's Avatar
Damn ! Sorry to here about this ! I know the feeling though.
__________________
Some thing for sale http://www.modularfords.com/forums/s...d.php?t=132013
Procharger F1-a ,302 stroker ,Lentech Strip Terminator with 3500 Billit race stall ,3:73 with True track and Moser axles, and Nitto 305/35/20DRs Best times 1.58/6.8/10.74 on old street tune 713/630 rw race 617/550 rw street
05stroker is offline   Reply With Quote
Old 09-05-2009, 06:23 PM   #3
prinzzz
prinzzz's Avatar
how hi are you taking the rpm's on those multiple WOT's. stock valvetrains are shortlived at 7000 or more
__________________
a whole bunch of shit 554rwhp/476rwtq
prinzzz is offline   Reply With Quote
Old 09-05-2009, 06:25 PM   #4
udelose
udelose's Avatar
Quote:
Its not stock valvetrain. MMR stage2 heads with nextec springs and MMR stage2 turbo cams.
They are good to 8000 plus.
__________________
Black 05 Stang
Old 09-05-2009, 06:59 PM   #5
hammeron
sorry to see it udelose, i hope the
rebuild goes well
hammeron is offline   Reply With Quote
Old 09-05-2009, 10:42 PM   #6
KIM_05_GT
So how high were you reving it? It doesn't look like the manley spring failed. Last I knew MMR used an off brand valve...
I personally would not rev any 4.6 past 7000
KIM_05_GT is offline   Reply With Quote
Old 09-05-2009, 11:54 PM   #7
TURBOTUNGSTEN
I have MMR stage 2 heads and stage 2 turbo cams, and my car makes peak power at 6300. It actually stops climbing hard at 5500 and just creaps on the power after that. I rarely run mine past 6 grand. I can shift anywhere from 5600 to 6400 and not have more than a tenth difference in et. Now with that being said, I do have my phasers locked, and I am sure that hurts power past 5 grand. Not saying that a 3v cant turn past 7 grand, just that I am not sure why one would need to (mild street strip engines/mild to moderate boost).
__________________
06 GT 5 speed, 70mm single turbo, BMR lower+adjustable upper control arms, Roush springs, axle exchange DS, rear end girdle, Livernois 5.0 stroker, MMR ported heads w/ big valves, MMR stage 2 turbo cams, Promotion 3650 trans, Spec stage 3 clutch, Fidanza aluminum FW. 570rwhp@11psi
TURBOTUNGSTEN is offline   Reply With Quote
Old 09-06-2009, 03:25 AM   #8
prinzzz
prinzzz's Avatar
the followers and lifters arnt
__________________
Reply
Bookmarks
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
