2005 - 2010 Mustang GT
09-06-2009, 09:37 AM
#9
Status: Senior Member
I'd get a look at the valve guide.
__________________
5spd, Whipple HO, Thump RR, LFP, JPC RACING, Autometer, BBR stage 2 billet cams, Centerforce, DFX clutch, MGW, JPC alum DS, Metco, J&M, Diablosport, JBA, Zoomers, Prothane, Steeda, RK Sport, Street Scene, CDC spoiler, Custom Quarter window scoops, Michelin PS, custom paint, tuned by Kevin MacDonald, 11.256, 1.52 60ft NEED A TIMING CHAIN WEDGE? PM ME
#10
i do not like dynos for one reason--- they beat the crap out of engines doing various tests---- more failures come from dyno runs---- yours probably just took a little longer to fail
__________________
ford headers,GT500 x-pipe,fr500s mufflers,GT500 62mm tb, cai,hurst shifter,raptor shift light,steeda motor mounts, & udp's,,swarr bar, Depo tail lights,hood pins, cdc chin spoiler,MRT rear window louvers, agent 47 lower grill, grillcraft upper grill, GT500 rear spoiler 3D hood scoop & side window louvers ford 4:10 ring&pinion LPW girdle,2010 ford clutch,APR rear diffuser,american muscle tune
09-06-2009, 10:20 AM
#11
Are they billet cams or regrinds? I'm assuming they are billet since you say they are good to 8000 rpm's.
__________________
09-06-2009, 10:47 AM
#12
Quote:
he floated the valves just like i did and had the exact same thing happen
__________________
a whole bunch of shit 554rwhp/476rwtq
09-06-2009, 10:52 AM
#13
the point I made was the tuner on the Dyno made several runs to 7000+ to see where the power would fall over. These are custom Billet cams not regrinds. I had 400+ regular street driven miles back and forth to work. When this happened I just filled the car up with gas and was pulling out of the gas station in second gear, at 1800 rpm.
I would have understood if this happened on the dyno at a high RPM... why it doesnt make sense to me is that it happened at 1800 rpm cruising speed of 35 mph...
__________________
Black 05 Stang
Current Mods: ProLine Shortblock, MMR stg2 heads, MMR stg2 turbo cams, TurboHorsepower Twin Turbo,
Numbers: 15psi, 17* timing, 722rwhp 689rwtq on a Mustang Dyno
Tuner: Frank Soldridge PSI Motorsports Inc.
09-06-2009, 10:53 AM
#14
How many R's were you running? Justin Burcham has been trying to get the stock pcm to allow more than the mid 7000 rpm range with his silver '05. His motor is good to 8k rpm's.
__________________
09-06-2009, 11:00 AM
#15
__________________
Black 05 Stang
09-06-2009, 11:03 AM
#16
did you notice a slight ticking before this happened. consider yourself lucky, mine took the cam with it. the lifter is proly f..ed up too
__________________
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
