2007 - 2010 Shelby GT500
11-11-2009, 02:45 PM
#1
Status: Senior Member
Stage 3 HE? Check! Stage 2 IC? Check!
Here we go again!!!
A while back I was contacted and asked to test some new cooling products and with all the talk about new AFCO coming out, I thought we would throw another one in the mix.
Currently on the way:
Stage 3 Triple Pass Heat Exchanger with twin 9” Spal Fans
Stage 2 Intercooler – This intercooler has been tested and ran on Hajek Motorsports 1500hp 2010 E-85/soy Mustang that set the land speed record at 258.41 mph! It has prov-en an efficiency rating in upper 90% range.
Heat Shield Gaskets and Pads – These Gaskets and Pads create a near impenetrable thermal Barrier between all of the intake tracks surfaces. The Composite developed blocked 500 TIMES the Surface to Surface Heat Transfer of any other gasket material available! See the chart below.
Dual Trunk Mounted Ice Tanks - With both tanks filled with ice, the hot fluid passes through the first tank to “Pre-Cool” it before it’s routed into the “Cold” Tank and back to the engine.
Eric will start testing the first HE in a couple weeks. Then the IC and Gaskets and finally the complete system with the Dual Tanks. I'll get the info out as it comes in so stay tuned!
__________________
2007 Alloy/Satin Silver KB GT500
752rwhp/630rwtq
11-11-2009, 05:43 PM
#2
Status: Owner / Administrator
Can't wait to get started on the install and see how well it performs.
__________________
ModularFords.com Owner / Administrator
Brooks Speed, Inc. - www.brooksspeed.com
11-11-2009, 07:17 PM
#3
Status: Member
Dammit Jim,Cruising at warp 11!!!
__________________
2008 GT-500,Evolution stage 2,10% lower,Escort 8500 Radar/Laser Detector,C@R cooling package,67mm twin throttlebody,570s at the wheels,BMR Boxed LCAs,Adj Panhard bar,J@M Uca,3.5 Aluminum Drive Shaft,FR3 Suspension,305/35/18 555r,Steeda Triax,Steige Blueprint and snout rebuild,Trufiber Hood.#2 of 314 Alloys Built.
11-16-2009, 09:47 AM
#4
Status: VMP Tuning
Cool, I had looked at using some of this stuff too just did not know when it would be available.
__________________
Justin Starkey Justin@VMPTuning.com VMP Tuning
2007 Shelby GT500 2.3L TVS 748RWHP/722RWTQ
VMP Dyno-Tune, VMP 2.65" Upper, VMP 72MM TB & Big Inlet Plenum/Elbow, VMP 115MM MAF, IW 10% OD balancer, 80s, Dynatech 1 7/8" LTs with 3" X pipe, stock catback
Old Time: 11.0 @ 130MPH 1.9 60ft on 18" DRs
2006 Mustang 4.0L with Vortech @ 15psi
2006 Jeep GC SRT8 6.1L AWD
11-20-2009, 01:27 PM
#5
i bought the gasket set and would like the intercooler, need your data first to see if its worth blow'n another load on this build.
11-20-2009, 01:42 PM
#6
can someone explain what gaskets are used?
The SC is going to get as hot (or hotter) than the motor itself...
So are these gaskets protecting the IC from the sc heat or from engine heat?
__________________
'10 GT500 vert - 12.81 @ 116 completely stock
12.45 @ 116 BMR UCA + LCA's
11.69 @ 117 BMR UCA + LCA's - No video proof
'04 Cobra Coupe- SOLD 5/31/09
10.48 @ 132 1.48 60' 10/3/08
11-21-2009, 12:12 AM
#7
The set consists of the SC, IC, Lower Intake and 4 thermal pads (not shown) placed under the intake.
__________________
752rwhp/630rwtq
11-21-2009, 12:10 PM
#8
Status: Member
Are the gaskets already on the market? If so where to purchase.
__________________
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
