Quote:
Originally Posted by Venmousracer
How hard was it to wire up the AEM ems system to the MOD MOTOR??? I am looking on using the AEM stuff for my 99 cobra that will be twin turbo'd. What is needed???? You built my dream car!!!! Awsome car..Eddie
Thank you, sorry for the long delay, it wasnt to hard to wire everything. Modular fords use weak magnetic VR crank and cam sensors, this required a few resistors to up the voltage and moving the jumpers on the AEM board from hall to mag. It will also require you to buy some sort of CDI, I went with an 8 channel AEM c2di, MY 1400 box only has 4 coil outputs, so we are running the engine wasted spark, the same way Ford and almost every manufacturer does it. If you went with an AEM 1900U you could fire all eight coils on there own. If you run low ohm injectors you will need a injector driver with the 1400 box but it is included in the 1900U. All in all it takes time but as with anything worth doing, it worth doing it right.
