I think with a little more seat time and traction in good weather it should go mid 10s. Car has 2.4 KB Crower stage 3 cams and a lot of bolt ons. Car is running 17lbs and dyno #s are 628 - 637 rwhp. Best trap speed was 132 mph.
WOW! Those are great runs!
If you could hook and keep that car straight low 10's would be easily obtainable.
Where is Ohio do you run at?
__________________ New Eaton TVS 2.3 under the hood! 03 Black Cobra Vert- 10.45@134 w/1.57 60' Tuned by Justin at VMP Tuning Powered by Lethal Performance
someone almost bit the dust. Your lucky you saved the car and it didnt hit the wall.
He didn't even come close. That's what happens when have a 3600lb 600hp missile.
It's called controlled chaos.
