| Turbo Terminators Technical discussion of Turbo-Powered 2003-2004 Mustang Cobra "Turbo Terminators" |
11-19-2007, 01:19 AM
#1
Status: HPP Racing
New best in the race car
We got a new set of tires on the 99 Cobra and took it out to the motorplex. They had the track preped great and we made 3 passes which were all good enough for new best. Right off the trailor it went 8.07@179, then we made another pass and it went 8.00@178 on the last pass it went 8.07@178. I weighed it once to see and it was 3175lbs. This car has a 4.6 based stroker motor, stock frame rails, 91mm turbo, & true 10.5" slicks.
We needed it to be consistent so we tamed it down on the line quite a bit. Just gave it a few more pounds up top and it picked up 5mph! We will be racing it in The Clash of the Titans next week down in Houston. We'll be running the true 10.5 class. Maybe we'll get our 7's down there. After that it's time for a tubo upgrade!
__________________
Manny
www.hppmotorsports.com
972-395-9844
The Racecar -Blue 99 Cobra : 7.79@180 on radials - HPP "Race" Kit, HPP Stroker, 3250 lbs.
The Streetcar -03 Sonic Blue Cobra, HPP Twin Turbo Kit
Street Car Progression:
Eaton=476rwhp 496rwtq , N/A = 305rwhp 287rwtq, Twin GT35R's = 820rwhp@19 psi., 10.10@137 at 3800lbs on 17"s.
302 ci stroker makes 1,080rwhp on 24 psi. or 975rwhp @19 psi.
11-19-2007, 09:19 AM
#2
Status: Mod fords slowest cobra.
Re: New best in the race car
No doubt you will get your 7 Manny, keep after it man.
11-20-2007, 02:36 AM
#3
Status: Senior Member
congrats, and good luck getting your 7 second timeslip!
__________________
Mike
98 Cobra Vert., 4.6 4v HP Twin 57's, Lentech 4R70W, Forged bottom end 9.2:1 Compression, ported b-heads, stock intake, stock throttle body, stock windshield wiper motor
10.33@ 135.6 1.58 60ft(horrible)
pump gas 17psi fat tune
11-20-2007, 09:59 PM
#4
Status: HPP Racing
Here is the video's from Saturday. I know the reaction times sucked, I wasn't really paying attention to that. I just wanted to make sure the launch rpm and everything was good.
Hopefully it doesn't rain this weekend!
http://videos.streetfire.net/video/7...ec0169608a.htm
__________________
Manny
972-395-9844
11-20-2007, 10:54 PM
#5
Wow, so damn close, you will get it, keep us updated,thanks for the video.
11-21-2007, 10:32 AM
#6
Man that was so close! Is that the same Blue car that use to have the twin setup on it ?
__________________
Built By HANS @ Deans Performance
Tuned By
Kurgan Motorsports
| Thread Tools |
| Display Modes |
Rate This Thread |
Linear Mode
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
HTML code is Off
