Quote:
Originally Posted by trey193
Nice swap and good running car as well!!! Couple of Q's?? How did you snake those huge coil pack wires under the valve covers? and secondly I see you are using a Fox style radiator , when you fill it do you do so through the cap on the radiator or the plug in the radiator hardline ???
thank you..if you mean the main harness for the coil packs ,they'r not realy huge its only 3 wires solder heat shrink and electrical tape with wire looms and voila oem appearance.
if you ment the sparkplug wires.in the back of the cop covers there is an oval indentation where the original
wireing went to the cops.the hole is big enough to fit 4 8.8 mm wires just right..
yes i got tired of all that plastic garbage resting on top of the cobra radiator..it didnt give enough room to swap belts pulleys it was just a headache to work on the front of the engine with it there..i went to a local speed shop bought a stock style radiator for a 93 older mustang and everything hooked up just fine. you fill it the same way as the oem stuff..
fill radiator to full capacity,put the cap on
then fill at crossover tube on engine till olso full.
run car till hot,let cool then top off again.
you should be good to go..
ps.
i found out that to burp the cooling system its easier to do it with the car on ramps or jackstands in the front...
