Total newbie here PLEASE HELP !!!!! procharger p1sc 03 f150 4.6
hello everyone im new to forums and new to anything with a power adder and I'm having a problem its a 03 f150 4.6 with a p1sc procharger with a 3 core intercooler and the problem im having is sometimes when I get into it weather its full throttle or a lil bit off the floor when I hit peak rpms and boost my truck just falls completely on its face like it ran out of gas or you just shut the key off it doesn't die it just lays over but you can let off the pedal all the way and then get back in it and its OK sometimes it'll run all the way through the fears at full boost and rpm and sometimes it doest it again then after a few pulls it will be ok I have no codes other than the iac but I took it out cleaned it put it back in and reset the codes and the problem still exist and now there is no codes if anyone has am idea or has experienced this your help would be greatly appreciated
