First off this is a buddies car bought from a used car dealership with the swap already done. It was a hack job that I am fixing multiple issues with,
Here are the particulars
2000 Gt 5-spd
Stock GTG3 processor
19 # Injectors
4v coil packs
No egr
No delta pressure feedback sensor
Stock mass air
Stock tune
Was brought to me as a no start condition, with no spark. Used my OTC gensis scanner and found a bad pcm, at the same time I found 5 different wires that were extended and spliced with wire nuts, crimp connectors, bare wire and electrical tape. I removed the engine harness and correctly soldiered each of the wires and connections and reinstalled it. I installed a reman processor from Ford and had them reset the pats system. The car now has spark, has fuel, but still wont start, it back fires intermittently through the throttle body. All of the connected sensors are showing proper voltages when I datastream it on the scanner. I went through a did a compression check and all of the cylinders are in between 185-195 pounds.
What am I missing??? It is acting like it is out of time but with the injectors and the plugs firing( and in the proper order) and the compresion being equal on both sides (broken timing or improper cam timing) I am at a loss.
Any input would be greatly appreciated
Thank you!!!
Adam
2000 Gt 5-spd
19 # Injectors
4v coil packs
No egr
Stock mass air
Stock tune
Thank you!!!
Adam
