How hard is it to replace the clock spring in an 02 GT. Mine is bad (long story). What do I need to do the job? Steering Wheel Puller? Take it to the dealership?
Easy job, disconntect battery, pull air bag, pull steering wheel (sometime a quick tug removes the steering wheel other times you need a puller), the biggest pain is removing the circular clip from the steering shaft, you will need the tool for that @$20
http://www.thetoolwarehouse.net/shop/KD-2414.html
After removing the clip, disconnect the clock spring then reassemble:tip:
yea usually you dont need a puller, if you have one it can make it a little easier but i dont have one whenever i have to take one off just loosen it up and shake the wheel and it will come off. but if you cant get it i know harbor freight makes a half decent puller kit for like 20$
Thanks guys!! I never had to monkey with the steering column, doesn't sound that bad.
