2003 Mustang Cobra
28k Miles
No accidents
Clean title in hand
Freshly painted in Dupont Single Stage Hot Rod black including all door jams, etc….
Vehicle was completely assembled by Insane Speed of Las Vegas.
Exterior:
Full color change in Dupont Single Stage Hot Rod Black (No runs or streaking)
Headlights, Taillights, and markers professionally blacked in flat
Bullet Wheels, painted satin black
Goodyear F1 tires 275/45/17 front
Mickey Thompson ET Street 315/35/17 rear
Calipers Painted Gloss Black
Chassis:
Certified 12pt WolfCraft 8.5 cage powdercoated black
Stock seats and interior
Brand New Black Carpet
VIS Cobra 3 inch Cowl Hood (latches in factory location)
Chevy Noose comes with
Engine:
Fully built 5.1 Stroker by Lawless Engines
(Lawless built all engines for Hot Rod Fuller's NHRA Top Fuel Team)
Fresh Core
Block Bored
Honed with Torque Plates
Line Honed
Balanced + Pin Fit
Ford V8 4.6 LT Pistons
4340 Crank w/3.750 Stroke
JE Straight Wall Pins
Custom Performance Coated Rod Bearings
Clevite Main Bearings
ARP Main Studs
380cfm Lawless ported heads
(These heads are 100% hand ported with over 100 hours into them. They became the blueprint for Lawless' full on CNC race head.)
Brand New Cores
Competition Port and Polish
Five angle valve job
Beehive valve springs
135.6 20 degree valves
116.3 30 degree valves
Ferrea Competition Valve Seats
Ferrea titanium retainers
Ferrea valve keepers
Ferrea spring seats
Ferrea spring locaters
Ferrea valve guides
ARP Head studs
Custom Grind Cams + Retainers
Ford 4.6 Head Gaskets
Maximum Motorsports Oil Filter Relocation
F1 Procharger Cog Driven
Cooling:
Custom Race Intercooler (Greddy Core)
Custom Aluminum Overflow Can
Custom Brushed IC Piping
Fluidyne radiator
Transmission + Drivetrain:
D&D Performance Viper Spec T56
Billet High Spline shafts
Fully Cryo'd Gears
Mcleod Street Twins Clutch
Upper Adjustable Clutch Quadrant
B+M Short Throw Shifter
Aluminum 1 piece driveshaft
Billet Rear Diff Bracing
Suspension:
Maximum Motorsports Complete K-Member Package
MM Tubular K-Member Brace
MM Front Control Arms
MM Urethane Bushings
MM Caster/Camber Plates
Bilstein Struts
MM Spherical Washer Rack Bushings
MM Lowered Sway Bar End Links
HyperCoil Coil Over Springs
Exhaust:
Kooks 1 3/4x3' Headers
Jet Hot Coating on Headers
Kooks 3 inch X-Pipe
SLP Stainless X-Pipe back
Electronics:
Weapon-X Xcop Ignition Coil Set
Diablo Computer
Fuel System + Intake:
Sullivan Performance Black Powdercoated Intake Manifold
Accufab Single Blade Throttle Body
Lethal Performance/Fore precision billet fuel hat W/ SINGLE 8an line
Twin Ford GT Super Car Fuel Pumps
Complete Sullivan Fuel System with 8an line front to back all with black earls an fittings
Aeromotive A1000 Fuel Pressure Regulator
Aeromotive 10AN Port Fuel Filter
Sullivan Polished Fuel Rails
Sieman Deka 63lb Flow Matched Injectors
Lethal Performance Dual Fuel Pump Driver Modules
Misc:
Flaming River Steering Shaft
To replicate this car will cost nearly $100,000 with the price of the car and complete color change. The engine ALONE will cost $25,000 to duplicate from Lawless. The car was completely wired and assembled by Insane Speed in Las Vegas and was tuned by Mike Angel of Insane Speed.
Everything is 100% brand new and has been broken in for 500 street miles before tuning. The car is complete and ready to hit the road.
I will consider partial trade for a clean 03-04 Cobra.
No mileage over 50k
No convertibles
No red or yellow cars.
Cash price = $48,000obo
Email me at
[email protected]. Videos and dyno graphs coming soon.
