Hey everyone, been a lurker for a while but I need some fresh ideas on this one. Cliffnotes...
03 Cobra
Built motor (9.2-1CR)
ported heads, cams
4.0L Whipple
123mm slot style maf
Full return fuel system, 80lb injectors
Headers, full offroad exhaust
all kinds of other junk that doesn't matter lol.
Car was previously running a 2.3 whipple on a stock motor which let go. I have very little prior history on the car before it showed up at my shop other than that alot of the previous work including the tune was poorly done.
Anyway, this car has a very serious case of spark blowout. Currently, the car is pullied for about 20lbs, running BR7EF plugs, stock coils. On the typical setup, 0.028" gap, the car breaks up bad under load. No load it will pull to redline, and on the highway it runs like a champ. As soon as load hits about 120% it breaks up bad and you can not drive through it. Gap the plugs down to 0.024" and it gets marginally better. I have had the car on the dyno, and have probably hours of logs, and the wierd thing is, no codes, A/F is good (or at least good enough that it should pull), pull the plugs and they look perfect, no vacuum/boost leaks, nothing that just jumps out.
Things I have tried: Swapped plugs, different gaps, etc etc. Load tested all coil circuits and tested pin fit on all connectors. Checked all grounds (PCM, chassis, engine, etc). Ran some auxilary grounds from the battery to the chassis. New alternator and battery. Swapped in different sensors such as maf, tp, ckp.
So, as a last ditch effort, I installed a boost-a-spark (which IMO shouldn't be needed). With the BAS cranked to 50%, the breakup/blowout is about 90% gone. It now only breaks up when it initially hits heavy load, about 3000-4000rpm, but you can now drive through it and it will continue on to 6000rpm (and WOW does it continue on LOL).
So, I still have some sort of an issue here. I have built plenty of these cars, and this one is just driving me nuts. I had access to some OEM equipment so I took a look at the mode 6 data. All cylinders are registering missfires, some worse than others, but all are. NO CODES. Power balance is all over the map under load.
What do you guys think? Possibly a fuel delivery issue that is making the spark issue worse? Maybe these FRPP 80's are just spraying like crap? The car idles quite well considering, short term trims are within 2-3%. Adjusting base pressure makes no difference, trims respond to DC changes, I don't know lol. PCM issue?
Sorry for the long post, but I am at a loss other than just continuing to throw parts at this thing (which I hate doing). Any input would be muchly appreciated.
Mike
03 Cobra
ported heads, cams
4.0L Whipple
Mike
