The rotating assemblies below are in stock ready to ship and this price applies only to these part numbers!!!
Standard Stroke Rotating Assemblies
2-Valve Centrifugal Supercharger 16cc - 9.7:1 Compression Rotating Assembly
4-Valve Roots Supercharger/Turbo 16cc - 8.6:1 Compression Rotating Assembly
Part # 459KIT4-2V/4VB Normal Price - $2,195.00 Sale Price - $1,695.00 + Freight (2 in stock)
4-Valve Centrifugal Supercharger 5cc - 9.7:1 Compression Rotating Assembly
Part # 459KIT8-2V/4VB Normal Price - $2,195.00 Sale Price - $1,695.00 + Freight (3 in stock)
4-Valve N/A or Nitrous Flat Top- 10.7:1 Compression Rotating Assembly
Part # 459KIT9-2V/4VB Normal Price - $2,195.00 Sale Price - $1,695.00 + Freight (3 in stock)
2-Valve N/A or Nitrous 10cc- 10.3:1 Compression Rotating Assembly
Part # 459KIT6-2V/4VB Normal Price - $2,195.00 Sale Price - $1,695.00 + Freight (4 in stock)
Stroker Rotating Assemblies
4-Valve N/A or Nitrous Flat Top- 11:1 Compression Stroker Rotating Assembly
Part # 459KIT7-2V/4VB Normal Price - $2,295.00 Sale Price - $1,795.00 + Freight (4 in stock)
2-Valve N/A or Nitrous 10cc- 10.8:1 Compression Stroker Rotating Assembly
4-Valve Centrifugal Supercharger 10cc - 9.7:1 Compression Stroker Rotating Assembly
Part # 459KIT3-2V/4VB Normal Price - $2,295.00 Sale Price - $1,795.00 + Freight (2 in stock)
Rated to 1,000 HP
Features:
Custom Livernois Forged Steel Crankshaft
Livernois Exclusive Mahle Forged Pistons
Mahle Rings, Locks, and Wrist Pins
Livernois Exclusive Manley H-Beam Rods w/ ARP 2000 Bolts
Clevite Tri-Armor Coated Bearings
Limited Lifetime Warranty - Click here for Details
* All Rotating Assemblies are Balanced and include MAHLE Pistons and Manley H-Beam Rods engineered EXCLUSIVELY for Livernois Motorsports
Note: Does NOT include main bearings. Please call and specify which block you have to order main bearings.
What sets Livernois Motorsports apart from the competition?
Unmatched Components
Clevite Tri-Armor Coated Bearings reduce friction and increase durability
Livernois Exclusive Mahle Custom Pistons have thicker ringlands and cross section than any piston on the market for big boost and power
Custom Livernois Rod designed in conjunction with Manley is now industry standard
Livernois Forged Steel Crankshaft good to 1200+ HP and modified on Livernois in-house CNC for enhanced oiling under extreme loads and RPM
Unmatched Quality
Products are built in climate controlled clean rooms so all specs are consistent
During the build process, each step is checked and rechaecked to ensure proper assembly
Each shortblock includes a detailed verification and spec check sheet
Unmatched Choice and Delivery
More shortblock combinations and specific power adder applications than anybody on the market
We ask you to compare our shortblocks against the competition
Unmatched Reliability and Endurance
Livernois Motorsports shortblocks are put through grueling test sessions on the dyno where our stroker engine package was first developed. Then hours of rigorous track testing was done to make sure we had a bulletproof package.
100s of hours of development and testing
100s of hours of cylinder finish development with state of the art Mitutoyo Profilometer to come up with a Livernois Exclusive honing system and finish that seals better and makes more power as well as controls oil and extends ring life
Lighter wright pistons than anybody in the industry for better RPM capability
Grafal coated Mahle pistons and phosphate coated ringlands and pin boss reduce friction and are standard in every Livernois Motorsports shortblock
Thicker tool steel wrist pin than any other piston manufacturer on the market is standard in every shortblock
Every block is race prepped by hand and is throughly deburred
Block oiling system modified for better oil flow and more consistent pressure under extreme conditions
Tighter tolerances (+/- .00015) than anybody in the industry
Every Livernois Motorsports built Rotating Assembly or Short Block is assembled by hand with the utmost attention to detail. Balanced and blueprinted with strict tolerances for quality, reliability, and performance unmatched in the industry! Livernois Motorsports has taken its experience in building winning race engines and applied that to its own line of performance engines for street/strip applications. From deburring and radiusing the blocks and pistons, down to the environmentally controlled clean room assembly procedures, Livernois Motorsports is confident that it is providing the customers with the highest possible quality in every engine that is built!
pm me or email rleblanc@livernoismotorsports.com
Thank you
Regards,
Rick LeBlanc
Rated to 1,000 HP
Features:
Unmatched Quality
Thank you
Regards,
Rick LeBlanc
