New Dyno Numbers with ARH Headers - Page 2
Page 2 of 3 First 123 Last
Results 16 to 30 of 40
  1. #16
    Senior Member Array 1bad03snake's Avatar
    Sep 2005
    Pearland ,TX
    196
    How did the install go? Did you drop the k-member?
    Matt
  3. #17
    Oct 2002
    Eastpoint, FL
    19,241
    I'm working on an install article.
    I did it the hard way I think, I did not remove the K-Member, nor the motor mounts. It was a bit tricky for sure. Passenger side is fairly easy, but the driver side is tough. Hardest part is getting the factory manifolds off, ARH headers went on beautifully, zero fitment issues.
  4. #18
    Senior Member Array Orlando Whipple's Avatar
    Apr 2005
    Orlando, Fl
    262
    Yeah i know what you mean Eric. There is a bolt on the driver side that absolutely blows. Basically from under neath we needed undo the motor mounts and use a pry bar to move over the engine about 3 inches and then could barely get to the nut. You pretty much have to have a flexible/pivoting head thruway ratchet.
    Then you have enough room to move the nut about 1/16th of a turn at a time. Fun fun.
    We are almost done on the Midnight run project video. Will be some good video on that.
  6. #19
    Senior Member Array Derek@DRI's Avatar
    Sep 2003
    Massachusetts
    4,365
  7. #20
    Senior Member Array Maniax Racing's Avatar
    Dec 2003
    southern md
    1,315
    where are the new numbers from a different dyno? Seems like alot of HP for just a header install, someone playing with #'s
  8. #21
    Oct 2002
    Eastpoint, FL
    19,241
    I'm not done with the article. No monkeying here, thats why I went to a DynoJet. You cannot manipulate the numbers. Don't be an asshole because I question your Mustang Dyno numbers.
  9. #22
    Dec 2003
    southern md
    1,315
    Quote Originally Posted by Eric Brooks View Post
    You sir really shouldn't call people assholes, some of us might get a little upset! Shows alot of class
  10. #23
    How about we see the Dyno numbers after the header work??? Im on the fence about headers and would love some info.
    Jason
  11. #24
    Oct 2002
    Eastpoint, FL
    19,241
    It's coming, I've gotta get the run files so I can post up some comparos from before the headers. The car gained about 6-8 RWHP and TQ everywhere, but the install of the headers caused the car to lean out about .5 a point as well. I have not been back to the dyno to put the fuel back in and see if the leaness or the headers actually caused the power increase.
  12. #25
    Senior Member Array
    Aug 2004
    403
    Eric,have you had time to take the shelby to the dragway since the KB?I bet you will love the results!
  13. #26
    Senior Member Array blueblazes's Avatar
    Apr 2006
    Hickory, NC
    309
    not to rock the boat but dynojets can be manipulated to how many tune pulley only cobras you seen make 540 hp without even somuch as a ported blower? Well theres a guy in sc with dynojet who claims this kinda crap.
  14. #27
    Oct 2002
    Eastpoint, FL
    19,241
    Quote Originally Posted by blueblazes View Post
    Other than running a car in 3rd gear, there is not much you can do to skew a DynoJet.
  15. #28
    Oct 2002
    Eastpoint, FL
    19,241
    Quote Originally Posted by dwhuff View Post
    Not yet. Still has stock driveshaft and suspension. Hopefully before the summer is up, i will have that fixed and some ETs to post.
  16. #29
    Dec 2003
    southern md
    1,315
    I have suspension but no drive shaft yet! I told Evo to bring one to The shootout just in case
  17. #30
    Last month @ the DiFeo day a GT500 blew his DS apart on his second pass of the day. IIRC - car had pulley swap and tune only
  18. Remove Advertisements
  1. New Dyno Numbers Are In!
    By bronxbomberz88 in forum 2005 - 2010 Mustang GT
    Last Post: 09-28-2009, 06:40 AM
  2. Dyno numbers in on headers
    By oldbones in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 06-05-2009, 11:10 AM
  3. dyno numbers are in!
    By blownstang in forum 1996 - 2004 Mustang GT
    Last Post: 10-02-2007, 11:47 PM
  4. Weight entered on the dyno, does this effect the dyno numbers?
    By BlownBlu97 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 08-28-2007, 03:06 AM
  5. LOW DYNO NUMBERS - Help
    By Casey99COBRA in forum 1996 - 2004 Mustang GT
    Last Post: 06-21-2006, 07:57 AM
Tags for this Thread
