S197 PCM CPUs... Spanish & Silver Oak
Results 1 to 2 of 2
    Senior Member Array mvon919's Avatar
    Nov 2006
    Next door
    1,025
    Default S197 PCM CPUs... Spanish & Silver Oak
    Intresting info about PCM CPUs used in S197. Spanish Oak (MPC565) (GT) and Silver Oak (MPC561) (GT500).
    MPC565: 32 Bit Microcontroller (used in Mustang GT S197)
    The MPC565 is a member of a MPC500 family of microprocessors that implements the PowerPC instruction standard architecture. The MPC565 is integrated with a Floating Point Unit, an advanced peripheral set and one megabyte of FLASH memory on a single chip. This combination is ideal for high performance automotive applications as well as other control-intensive applications.
    Features:
    1M byte of internal FLASH memory (divided into two blocks of 512K bytes)
    • 36K bytes Static RAM
    • Three time processor units (TPU3)
    • A 22-timer channel modular I/O system (MIOS14)
    • Three TouCAN modules
    • Two enhanced queued analog system with analog multiplexors (AMUX) for 40 total analog channels. These modules are configured so each module can access all 40 of the analog inputs to the part.
    • Two queued serial multi-channel modules, each of which contains a queued serial peripheral interface (QSPI) and two serial controller interfaces (SCI/UART)
    • A J1850 (DLCMD2) communications module
    • A NEXUS debug port (class 3) – IEEE-ISTO 5001-1999
    • JTAG and background debug mode (BDM)
    MPC561: 32 bit Microcontroller (used in GT500)
    Features:
    Precise exception model
    • Extensive system development support
    • On-chip watchpoints and breakpoints
    • Background debug mode (BDM)
    • IEEE-ISTO 5001-1999 NEXUS Class 3 Debug Interface
    • True 5-V I/O
    • Two time processing units (TPU3) with eight Kbytes DPTRAM
    • 22-channel MIOS timer (MIOS14)
    • Two queued analog-to-digital converter modules (QADC64_A, QADC64_B) providing a total of 32 analog channels
    • Three TouCAN modules (TOUCAN_A, TOUCAN_B, TOUCAN_C)
    • One queued serial module with one queued SPI and two SCIs (QSMCM) 32-Kbyte static RAM (CALRAM)
    This data shows the complexity of the 3V engine mgmt... Silver Oak is stripped proprietary model from Spanish Oak. Both have same components, but Spanish Oak has more channels to control. Check www.freescale.com for more info (search with part numbers).
    Senior Member Array 05xgt's Avatar
    Oct 2006
    Houston TX
    522
    I have no clue what I just read.LOL even after trying to disect. Truly a world of higher intelligence.
  4. Remove Advertisements
  1. S197 MGW silver anodized cupholder bezel
    By Rudiepoo1 in forum 2005-2010 S197 Mustang Classifieds
    Last Post: 12-17-2009, 04:12 PM
  2. Intuitive learning with the Spanish Oak computer.
    By Slofoot in forum 2005 - 2010 Mustang GT
    Last Post: 10-26-2006, 07:17 PM
  3. Looking for Manual on Spanish Oak operations
    By Tbone69 in forum Tuning and Diagnostics
    Last Post: 10-14-2006, 10:56 AM
  4. Can the spanish oak ecm be switched to an EEC-V?
    By spyder7724 in forum 2005 - 2010 Mustang GT
    Last Post: 07-07-2006, 10:16 PM
  5. Spanish Oak?
    By Tbone69 in forum 2005 - 2010 Mustang GT
    Last Post: 06-05-2006, 01:14 PM
