Page 1 of 15 1234567811 ... Last
Results 1 to 15 of 218
    Moderator Array BADASS03SVT's Avatar
    Dec 2003
    Boston
    8,802
    Default Tuning: Dyno A/F vs Wideband A/F
    Im going to play on the dyno next week and wanted a little more aggressive tune done. We got the car right at 11.6-11.7 on the dynojet wideband but my Innovate wideband reads 11.0. Has anyone tested to see if the widebands are accurate? if I can lean it out a bit might be able to pick up a few ponies by using the wideband for a/f.
    Oct 2002
    Eastpoint, FL
    19,231
    I've been meaning to make a post on this topic and I probably will (and supply data) in another thread.
    I have little faith most widebands, specifically the ones that utilize a Bosch sensor.
    I ran my wife's Mustang on my dyno, and put the DynoJet wideband in the rear 02 sensor bung, made a pull, and the airfuel was off the charts rich. Meaning richer than 10.0:1
    I then put in my AFM-1000 wideband in the same spot, and made another pull and the airfuel was 11.5:1.
    If I were tuning the car with the DJ wideband, I would have pulled fuel out to make the airfuel look better, but would have ended up with a dangerous mixture.
    Just my experience.
    Dec 2003
    Boston
    8,802
    Quote Originally Posted by Eric Brooks View Post
    Just my experience.
    wow...yea...thats a big difference!
    in my case also, the dyno sniffer is at the tailpipe AFTER the hi-flo cats and my wideband is right before the cat. not sure how a cat affects the readout?
  6. #4
    Oct 2002
    Eastpoint, FL
    19,231
    After cat will slow slightly leaner, near the start of the pull when the catalyst is full of oxygen.
  7. #5
    Senior Member Array SilverBoost's Avatar
    Jul 2004
    Winter Garden, FL
    1,188
    this is no good. If this holds true then owning a wideband in a car is a waste of money.
  8. #6
    Senior Member Array 03WhiteGT's Avatar
    Dec 2003
    Midlothian, Texas
    313
    Subscribing
  9. #7
    L&M build in progress! Array 04MystiCobra's Avatar
    Jan 2004
    CC, TX
    1,461
    Dont forget to read plugs too.
  10. #8
    Senior Member Array FULLBLOWN03's Avatar
    May 2005
    Tuscaloosa,AL
    709
    I have been tuning my car with an innovate lc-1 for the past three years, but i like to tune mine on the street. I even had the kb2.8 at 27psi tuning to this wideband never had any problems so i trust it. Just keep a fresh o2 sensor in it every now and then.
  11. #9
    Moderator Array NeverEnuff's Avatar
    Nov 2006
    TX
    3,942
    My dyno shops WB reads quite a bit leaner than my WB in my car. I sit in the 11.5 range and he reads low 12s to 12.4ish. Then when I stuck his WB IN my pipe his read like mine. So I will believe mine before I will believe a tube stuck in my tailpipe.
    Now I know I don't have a ton of experience...but this is of course just what I have seen and done.
  12. #10
    Senior Member Array BLK_03's Avatar
    Sep 2004
    St. Louis, Misery
    6,795
    Just my experience.
    New sensors on both and freshly calibrated?
    That is quite a difference.
    If I'm going to be making tuning adjustments to the car, the first thing I do is install a new sensor and calibrate it.
  13. #11
    Oct 2002
    Eastpoint, FL
    19,231
    Quote Originally Posted by BLK_03 View Post
    Yes
    I working with someone very knowledgeable on UEGOs to give me some information on the differences. Its not all the sensor, a great deal of the accuracy comes from the electronics.
    The NTK sensor for my wideband costs what an LC-1 costs.
  14. #12
    Dec 2003
    Boston
    8,802
    Quote Originally Posted by FULLBLOWN03 View Post
    this was what I was about to ask...who street tunes their cars? Ive seen a few people mention this in threads and wonder who's wideband they are using.
    I mean...which is correct and how can we tell??
  15. #13
    May 2005
    Tuscaloosa,AL
    709
    Quote Originally Posted by BADASS03SVT View Post
    I was having Jon Lund(one of the best IMHO)tune my car. I would do some logs on the street email him the logs and he would adjust my tune accordingly. Like i stated I have logged and tuned to this wideband for 3 years and my combo has changed alot in those 3yrs.
  16. #14
    Oct 2002
    Eastpoint, FL
    19,231
    I'm not saying you can't use one of these widebands for tuning, but just know that there is a good chance the airfuel isn't that accurate. More info coming soon.
  17. #15
    Senior Member Array
    Jan 2003
    Toledo, OH
    6,841
    Is there a better replacement available to use in place of the Bosch with the Innovate and DJ widebands?
  18. Remove Advertisements
  1. Tuning in Open Loop with wideband
    By hmg_57 in forum Tuning and Diagnostics
    Last Post: 12-04-2009, 05:27 PM
  2. Tuning with Wideband in Car
    By NasZBte in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 01-08-2009, 05:08 PM
  3. SCT XCal2 + LC-1 Wideband & FREE Tuning = $499!
    By James Parker in forum 2005 - 2010 Mustang GT
    Last Post: 06-08-2007, 02:35 AM
  4. Amazon Tuning Solutions Dyno Tuning Day Video in Louisiana
    By BLOWN03SNAKE in forum Pictures and Videos
    Last Post: 05-12-2006, 05:51 AM
  5. How critical is Dyno tuning vs. Mail order tuning
    By JaxCobra03 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 05-18-2005, 09:42 AM
