1 - 20 of 29 Posts
I've decided that this is the goal I'm shooting for and wanting to know if anyone has an 11s 3v, and if so what setup are you running?
05 BOSS 302
11's n/a can be done. There are quite a few guys that have gotten consistant 12.5-12.6 with headers intake, CMCP deletes, under drives, driveshaft, gears and tires. You also need the proper suspension and a bit of lightening as well. Add the right combination of heads and cams and you should be knocking at the door of low 12's high 11's.
we gonna see. My next mods are a C&L race CAI, comp stage II cams and springs, and Mac LTs with a MAC prochamber
On my way, a lil wt reduction and get this dam rear end fixt....
...gonna try w/ stock tb and intake...:tip:
well your ahead of me in the mods nut I hope to catch up.
what part of Louisiana you from? I'm in B.R.
.... in Lake Charles.
Usually go to Evadale track b/c only 45min away; but frequent SCR and HRP.
u SHOULD ASK JIM D'AMORE JR OF JDM.WHAT HIS SET-UP WAS..HE WAS A CONSISTANT 11.0 GUY N/A
11's yes, I did not know he'd gone 11.0;
...he has Livernois built 298 bottome end, auto, stall, etc... and a Edelbrock s/c now...
I read somewhere there's a N/A automatic car running low 11's with a 302 stroker, anderson ford N43 cams, ported heads and of course every other bolt on in the market.
That has been my goal as well. I'm almost there. Ran 12.0s last month. With light weight drag wheels or the new C&L manifold thats due out,I should be in the 11.80-90s. We shall see soon.
Jim had a 298CI Stroker with full bolt ons, longtubes, heads/cams, 4:56 gears and some suspension parts, and he ran 11.15
Discussion Starter · #13 ·
thanks
Yep 11.15 is my best, did it at 119 mph but the car has been [email protected] The most part of my power came from the 298 stroker and ported heads/comp cams. This engine made right at 400 HP to the tires through an automatic. The torque converter and gears also made a big difference. I was able to get 1.53-1.55 60 foot times to run 11.1's. The car weighed about 3400lbs with me in it. 3220 with out me. I could have gotten another 60 lbs out of it too. However this was before i added a roll cage. If I had gotten the C&L manifold on i think i could have gone 10's, even with the cage in the car. I wanted to do this but was offered a Edelbrock supercharger and new engine from my father...couldnt pass it up!
Thats awesome times. Congrats ! I still have a stock bottom end.
I hope you run 10's with it flying. Its sad Jim didnt have the time to do it
1 - 20 of 29 Posts
