1 - 19 of 19 Posts
Anyone know who makes the 13" Cone Air filter? Running a 12" now and want bigger.... I have googled and browsed K&N and S&B and could not find it. Not sure if I am just over looking it.
You don't necessarily need a longer filter. Call S&B and ask about their filters with a taller pleat height. It's all about increasing filter surface area. A taller pleat accomplishes this just like a longer filter does.
JLT made one for David King :tip:
Damn thanks everyone. I need to make 100% sure the amount of room I have to work with. The 12" may be all I can do but I will check on the taller pleats.
Ok went through S&B website on Universal air filters and the best that they have is 12" with 0.5" pleat which is what I am running now. Could not find where I could custom design one.
Call them and ask. I know that they are working on filters with taller pleats than 0.5in.
GodStang
What size inlet are you using ?? I have a OLD style "BIG MOUTH " S & B (12" x 7.25" x 5.25" ) with a metal adapter from 6" to 4"!!!:tip:
I am thinking its the 12"x4". The inlet is not my problem its the surface area. It flows roughly 1332.62 cfm according to the data I found. I need to increase that by about 300cfm. Now maybe these numbers do not take into account for pleat height. I will get in contact with S&B and see what they say.
GodStang
The NORMAL 12" S & B filter is (12" x 6" x 5.25" ) !!! The "BIG MOUTH" is about 1" OD larger.:tip:
Discussion Starter · #12 ·
Response I got:
Joshua - you should be running a filter with a minimum surface area of 1000 sq. in., the filter you currently have (RO872) has only 681 sq. in.
If you have the room here is a filter (CR-90026) that will fit the 4" MAF housing. It has a surface area of 1035.2 sq. in. utilizing a pleat depth of 1.200", a base diameter of 8" and a top diameter of 7" and is 8" long.
Next week we will be releasing a new line of large universal filters that have a pleat depth of 1.750", we will have a 4" diameter flange (R1262) that has a base diameter of 9", a top diameter of 7" and is also 8' long with the surface area increased to 1181.25 sq. in. However it looks like you will not have the room for a 9" diameter base, so your best bet is the CR-90026. This CR-90026 is our version of a replacement filter for one of AFE's diesel intake kits, notice how much we improved the flow over the AFE filter.
http://www.sbfilters.com/products/product_display.php?part_number=CR-90026
Interesting info.
The Canadian Snowbra
I don't want to hijack, but can anyone suggest the correct filter size for a pullied Eaton, with light mods?
I think I'm going to buy a shield and an adapter to connect a filter and just run it like that (stock inlet tube).
The only way to match the "correct" air filter to the rest of the cars setup is to know the flow rate of the blower/engine.
No one can tell you the correct filter for "a pullied Eaton, with light mods".
--Joe
--Joe
So you're saying that out of all the setups that have been tried and tested on this board, that there's no general consensus on the average filter size needed for a stock long block, with a 2.75 upper Eaton? No one has a general idea of the flow rate on that setup?
I find that somewhat difficult to believe, I'm not looking for exactitude, simply a general idea of what is needed to make sure I don't create a restriction.
Discussion Starter · #17 ·
I know exactly what you flow but the general consensus is 9" S&B is great and if you can added a 12" thats even better.
:tip:Much appreciated, is there any reason that S&B seems to be the general choice?
Discussion Starter · #19 ·
S&B comes with JLT and most are running JLT. I also like S&B over K&N. Just cause but if you can find it in K&N it will do you fine.
1 - 19 of 19 Posts
