setup questions
Results 1 to 6 of 6
Thread: setup questions
    Default setup questions
    i have a v2 t-trim and i was wondering on issues that i might have with the setup i want.
    1. is it better to run a blow thru or draw thru MAF?
    2. if i run a blow thru, can i run it with no intercooler?
    3. what pulley do i run if i wanna get around 400-430hp
    4. with the pulley on #4^ what injectors do i run to make the 400-430hp
    5. is a blow thru or draw thru easier to tune?
    those are some questions for now... i have a 03 GT and v2 t-trim with a base kit, stock internals and i wanna make 400-430hp 400-430tq.
    any advice is greatly appreciated. Thanks!!
    Senior Member Array vidmaster's Avatar
    Nov 2006
    Brick, NJ
    2,760
    Quote Originally Posted by BJs03GT View Post
    1. blow thru, easier to tune and better drivability (pmas hpx meter with a 05+ mustang pigtail that you splice onto your old maf plug)
    2. i wouldnt, a lot of tuners have had problems with turbulence due to the maf being too close to the blower
    3. I made 420ish thru an auto on a 3.33. You will prob need at least a 3.33 or a 3.2/3.1 pulley (def going to want an intercooler imo if you run anything more than the stock 3.6 pulley
    4. 42lb injectors are fine, but 60s arent much more. If you don't have injectors yet just get 60s and your tuner can setup the tune for them. You'll have more than enough fuel if you decide to turn up the wick more. Think 42's are done around 450-475rw but not 100% sure. Make sure rest of your fuel system can keep up
    5. see #1, blow thru is easier to dial in usually
    Vid master:How nuch boost you running with your setup? You have a s-trim wouldn't I make the same boost as you with a bigger pulley cause I have a t-trim?
    Also I don't want to run a BOV but I want a louder than stock BPV which one should I get?
  6. #4
    Nov 2006
    Brick, NJ
    2,760
    hey sorry just noticed you said t-trim. Not sure how the pulley sizes vary with the T's. My S w/ the 3.33 makes like 10-11 lbs @ 6k and 13 lbs @ 6500
    i run the procharger red race blow off valve. I would go with either a maxflow from vortech or the procharger big red bypass. Just keep in mind you will have to modify the pipe for the bigger flange required with the bigger bypass valves so you will need someone who can weld for you if you cant do it
  7. #5
    so i think if i run 1 size bigger then yours i should be making the same boost. i think ?!?!?
  8. #6
    anyone know the exact size pulley i should be running to make 9-10psi and around the 400 make hp? i wanna know before i purchase one
  9. Remove Advertisements
  1. N/A setup questions??
    By john2424 in forum 1996 - 2004 Mustang GT
    Last Post: 08-23-2009, 12:10 PM
  2. Questions on my new setup with the KB 2.8L H
    By BlownBlu97 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 02-19-2007, 11:41 AM
  3. New Setup Questions
    By Zinc712 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 02-17-2007, 01:28 PM
  4. 2.93/4lb setup questions?
    By venomousSB03 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 12-05-2005, 01:16 PM
