adding a shim or clutch disk to diff??
Results 1 to 7 of 7
    Senior Member Array 03SVTCOBRA10TH's Avatar
    Sep 2003
    South East
    1,523
    Default adding a shim or clutch disk to diff??
    I think my diff is shot............. I want to try to add a shim or extra clutch disk to the diff with the rebuilt kit........... Any one done this before???? What spec should I shim it to???? Should I just look at an after market diff.....Any sugestions??
    Senior Member Array IWRBB's Avatar
    Jan 2003
    4,518
    Just rebuild the T-Loc.
    I did it in my 94. I got a kit from Pyle Brothers out of Texas. It had thicker clutches and thinner metal discs. Plus it had instructions for packing it tighter. You can do it with the regular clutches and by using a different stacking technique.
    If C is a clutch and P is a plate,
    Stock is something like CPPCPPC, you want CPCPCPC
    So you will need two kits as mentioned for the extra clutches, and will have to reuse your least worn used clutch to make it all fit.
    Senior Member Array VIPERBLUELX's Avatar
    Aug 2003
    Ringgold, GA
    1,717
    rebuild it with one extra friction on each side. Just save the best 2 out of the old ones you take out so you don't have to buy 2 kits.
  6. #4
    Senior Member Array SinisterX's Avatar
    Oct 2003
    West Central, NY
    669
    buy the Ford clutch pack kit $60 you get a a bunch of extra shims each one is a different thickness.
    The shims come in pairs for both sides.
    I used the next bigger size than stock for my GT and the rear was tight as a drum.
    In grass or dirt, the rear was almost a posi.
    It will shutter for some time, just go to a parking lot and do some figure 8's until it's gone. Your golden. I wish I would have redone my Cobras when I added MJ's brace.
  7. #5
    Sep 2003
    South East
    1,523
    Ok Thanks guy!!!!!!!! Does anyone know for sure what the stock setup is
    or is this just a guess........... and are you sure that it should then be changed to every other one???? Thanks!!!!!!!!!!!
  8. #6
    Junior Member Array rel3rd's Avatar
    Apr 2003
    Baltimore, MARYLAND
    28
    Icon14
    Quote Originally Posted by 03SVTCOBRA10TH
    You are correct...if you remove every other "steel" or "plate" you'll have the room for the extra clutch. You'll probably need a thicker than stock side shim, which also comes with the new clutch pack kit. I've done several this way, both for myself and for friends...
  9. #7
    Sep 2003
    South East
    1,523
    Quote Originally Posted by rel3rd
    How many thousands do I shim it to......... Should I shim to stock specs??? Waht is the stock spec???? Thanks!!!!!!!!
  10. Remove Advertisements
  1. 04 Cobra Clutch Pack ? (Replace or shim)
    By Capone in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 03-21-2011, 04:56 AM
  2. 3650, SPEC Clutch & Stock Slave - Shim?
    By michael.konor in forum 2005 - 2010 Mustang GT
    Last Post: 06-18-2010, 09:40 AM
  3. Difference between a Ford T56 Clutch Disk and a GM T56 Clutch Disk??
    By Screamn03 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 02-18-2007, 10:46 AM
  4. size of shim for spec clutch installations
    By 05yellowGT in forum 2005 - 2010 Mustang GT
    Last Post: 05-23-2006, 09:11 PM
  5. Lowering car and adding diff brace. Bushings?
    By SpoolinSnake in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 02-17-2006, 07:57 AM
