Would -8AN be too small for oil supply?
Results 1 to 13 of 13
    Senior Member Array Stock4VGT's Avatar
    Sep 2007
    Indiana
    360
    Default Would -8AN be too small for oil supply?
    Quick run down of the setup, is a modded 4v w/ a 3.4 and a Hi-Vol. Melling oil pump. I have everything remote mounted.
    I bought the MM oil relocation system minus lines and fittings a while back because I wasn't exactly sure how I was planning on running the lines, because I have a Perma-cool oil cooler and Earls Thermostat in the system. I am about finished the car, and this is my last step to take. I pondered using -8, and instead thought of -10 since that is what MM uses for there kits. Would you guys think that the -8 would be fine since the ID is 7/16? -10 is only 9/16 ID, and I don't think that it will hurt anything. I just want some other opinions. This is mainly a cost thing, because I could save myself quite a bit w/ the -8.
    Moving on up... Array Smokin04's Avatar
    Mar 2005
    Goldsboro NC
    4,775
    Really good question. I kind of agree with you that the -8 shouldn't affect things that much. The pump controls volume and flow, so the orifice (-8 or -10) would essentially only affect velocity which in the oil system, doesn't matter.
    Sep 2007
    Indiana
    360
    Quote Originally Posted by Smokin04 View Post
    I don't think that I should have anything to worry about, maybe if I had over 1,000 hp and I was running an extermal oil pump which pumped a ton more volume of oil. Being that this its only an 1/8 of overall diameter size then this will be fine. I could probably save myself in the neighbor hood of $100 in fittings and hoses. Anybody else have an opinion?
    Also I might add that this will be a street driven car 90% of the time, and will never seen any roadcoarse action, but maybe some drag strip time.
  6. #4
    Senior Member Array 4vPOWER's Avatar
    Jul 2008
    Garden State
    157
    I bought the MM relocation complete kit. There must of been a good reason that the kit included -10 line and fittings. They could of made the kit cheaper if they supplied -8, but instead they pick -10.
    I used -8 as my fuel supply line. If you actually measure the inside diameter of it, it's only 3/8".
    Think of it this way, if you blew your motor for trying to save a hundred bucks. Would it be really worth it.
    I wouldn't skimp out when it comes to lubrication life blood for the motor. But that just me.
  7. #5
    Sep 2007
    Indiana
    360
    nominal ID for the hose i bought (Fragola 3000 Series) states its 7/16. I appreciate your opinion, and I agree MM had to have a reason for -10, but maybe somebody has made -8 work. Thats what I'm looking for. I have -8 on my fuel rails as well.
  8. #6
    Jul 2008
    Garden State
    157
    I'm sure -6 would work too (isn't that what turbo feed line uses) and you would save even more money than -8.
    The smaller the line, the less volume of oil it will flow, being that oil has a much higher viscosity than fuel which makes it tougher to flow especially when cold. When you have your oil filter off, look at the size of the hole of that filter stud. It's much bigger than -8 size.
    That is probably why MM supplied -10 and that's borderline too small. Nascar guys are using -16 for their oil supply line.
  9. #7
    Senior Member Array
    Jul 2003
    In a van, down by the river
    1,499
    YES -8 is too small
    you're trying to flow VOLUME so you want MORE MORE MORE. -12 if you can fit it. -10 is the minimum.
    but hey, its your engine. if you want to cheese out on the oil flow, might as well use a half-height filter too, rather than relocate. Its just the lifeblood of your engine, and does more work to cool it than the anti-freeze does...but hey...its your money...
    on edit: i hope you increased your oil sump capacity with that high volume pump. a high volume pump doesn't get the oil back to the pan any sooner. sucking the sump dry is bad, mmkay...
  10. #8
    Sep 2007
    Indiana
    360
    Quote Originally Posted by ShelbyGuy View Post
    YES -8 is too small
    Canton 7 qt. w/ windage tray. Thanks, i appreciate the input. I'm not trying to skimp by any means, because i've already dropped a ton of money into it, i'm just checking to see what ya'll would recommend. I'll look into -12 as well if you think thats what it really needs.
  11. #9
    -12 is what I used.
  12. #10
    Sep 2007
    Indiana
    360
    Quote Originally Posted by fordfan View Post
    -12 is what I used.
    Can you explain what you setup is?
  13. #11
    -12 hose out of the karkraft external oil cooler adapter to a canton remote oil filter to a mocal oil thermostat (-12 in/out) back to the adapter on the block. -12 lines go from the oil thermostat to a mocal oil cooler. When the oil temp reaches 180 the thermostat opens flow to the oil cooler. It is aeroquip hose and I used the reusable aeroquip fittings. I bought an AN wrench set to use with the fittings.
  14. #12
    Moderator Array
    Dec 2004
    Hildebran, North Carolina, United States
    2,441
    -10 is what I used... I bought the kit complete originally but I just got finished with redoing my relocation lines. I didn't like the way the lines ran and the braided stainless line is hard to route because it is so stiff. I replaced all my fittings/line with Earl's Ano-tuff fittings and Prolite 350 hose. It's routed better and I didn't have to run it in between the PS hard lines this time either
    It is a little cheaper to buy -8AN fittings/line but as ShelbyGuy said -10 should be the minimum size you choose to use.
    Shannon
  15. #13
    Sep 2007
    Indiana
    360
    Ok, thanks guys. I went ahead and ordered the -10 shiznit today
  16. Remove Advertisements
  1. Fuel supply advice
    By SSRGT03 in forum 1996 - 2004 Mustang GT
    Last Post: 03-27-2008, 10:08 PM
  2. Fuel supply hinderance!
    By 169stang in forum 2005 - 2010 Mustang GT
    Last Post: 09-15-2006, 12:29 PM
  3. Need Oil Supply Fitting for Oil Pan.
    By 2003Slobra in forum Turbo Modular
    Last Post: 11-30-2005, 06:49 AM
  4. Fuel supply issue?
    By jtchristianson in forum Modular V8 and V10 Conversions and Swaps
    Last Post: 03-02-2005, 08:39 AM
