Complete Eaton Swap/2.3L Whipple + More!
Results 1 to 8 of 8
    Senior Member Array SIrRicCuS's Avatar
    Sep 2006
    South Orange County, CA
    243
    Default Complete Eaton Swap/2.3L Whipple + More!
    I recently bought a turbo setup for my Terminator so all of this blower stuff is going to have to go. :D
    Coming with this Eaton swap will be the following upgraded components...
    • Goodyear Gatorback Supercharger Belt
    • Lethal Performance EGR Delete
    • JLT True Ram Air Intake
    • SCT BA2400 MAF
    • Billetflow Snub Idler Bracket With 4 Piece Idler Pulleys
    • Metco 4lb. Lower Pulley
    • Metco 3.2” Alternator Pulley
    • LFP Dual Pass Heat Exchanger
    • Precision Fabrication Intercooler Reservoir
    • Custom Intercooler On/Off Relay
    Just the upgraded parts alone were almost $3,000.00.
    The only thing that I'm going to need to utilize from my current setup is the Billetflow Single Blade Throttle Body. Other than that, pretty much everything that is necessary to convert a '99/'01 Cobra or '03/'04 Mach 1 will be included in this kit and this is an extensive swap including the timing chain cover among other things unlike other kits I've seen.
    For those of you with '96-'98 Cobra's, I've even got a set of complete '01 Cobra heads so that this swap could be done on your cars. ;-)
    Here is a thread on the Mach 1 Registry about the swap with a detailed list of necessary components.
    Mach 1 Registry - Eaton Swap.....
    I'm selling the Eaton swap complete with Whipple for $6,000.00. Prefer not to ship, but I will do so if necessary at the buyers expense. And I prefer not to break this kit up either.
    If broken up, the Eaton Swap will be $3,750.00 and the Whipple will be $2,750.00.
    I also have a Terminator fuel hat, pumps, lines, FPDM, and Kenne Bell Boost-A-Pump for those that are interested in going all out. I'll sell the entire fuel setup for $500.00.
    Here are a few other miscellaneous items I've got for sale too...
    60lb. Siemens Deka High Impedance Fuel Injectors with Harnesses $275.00
    Stock Terminator Injectors $120.00
    Complete '01 Cobra Heads $750.00
    Metco 6lb. Pulley Ring $65.00
    MGW Cobra Emblem Shift Knob $40.00
    Here is pretty much what your engine bay will look like.
    I made 610 RWHP/565 RWTQ on 15psi with this setup and it runs extremely hard. Here are a couple of videos from when it was tuned.
    For serious inquires, feel free to call me with any questions you may have.
    Ricky Raus
    714-264-0050
    Senior Member Array
    May 2009
    kernersville
    687
    If you ever want to break up you eaton swap kit I'd like your intercooler reservior.....
    Sep 2006
    243
    Quote Originally Posted by 04svtsnke View Post
    I appreciate the interest and I'll keep you posted. I might just swap all of the upgraded components for stock pieces and sell the Eaton Swap for a lower price. That seems to be the trend, at least. I see these kits going for $3,200.00-$3,500.00 with completely stock components and I'm asking for only a couple of hundred dollars on top of that for A LOT of upgraded components. I think it's more than reasonable, but the way the economy is, it doesn't surprise me that people are short on cash.
  6. #4
    Senior Member Array
    May 2009
    kernersville
    687
    exactly.....but ill be waiting if you ever want to let it go seperatley, ill even trade you my stock on so youll have one to go with your swap kit...let me know if that could work...
  7. #5
    Senior Member Array SloSVO's Avatar
    Dec 2007
    Wild Wild West
    432
    what gen is the whipple?
  8. #6
    Sep 2006
    243
    Quote Originally Posted by SloSVO View Post
    Gen 1.
  9. #7
    how much for the eaton and stuff.
  10. #8
    Sep 2006
    243
    Quote Originally Posted by venomcobra View Post
    All of the prices are listed in post #1.
  11. Remove Advertisements
  1. pretty complete eaton swap
    By stickcar1990 in forum Engine Parts
    Last Post: 08-13-2010, 10:09 PM
  2. WTB: Complete Eaton Swap
    By supersnake730 in forum Power Adders
    Last Post: 04-25-2010, 11:33 AM
  3. fs: eaton swap complete, and 2.3 whipple
    By Blownnotcher in forum Power Adders
    Last Post: 02-12-2010, 06:12 PM
  4. 03 cobra complete eaton swap
    By 88mph in forum Power Adders
    Last Post: 01-30-2010, 05:30 PM
  5. Need a COMPLETE Eaton swap
    By ScottyG in forum Power Adders
    Last Post: 07-26-2008, 09:39 AM
