Aluminator build
Page 1 of 2 12 Last
Results 1 to 15 of 29
    Member Array explict's Avatar
    Mar 2008
    Fort McMurray Alberta
    45
    Default Aluminator build
    Hey,
    I've been a creeper on this forum more than anything. But I thought I would post my build up anyways!
    Engine:
    Ford Aluminator 3V 4.6L
    8.7:1 CR
    Forged aluminum 16cc dish 3 valve pistons
    Forged steel crankshaft
    H-beam connecting rods
    FRPP Oil pump
    ARP Head Studs
    ARP Crank bolt
    Ford head gaskets
    P&P Heads with BBR stage 2 cams
    Whipple 2.3L GENII Twin Screw 10psi kit
    Whipple Inter-cooler
    Fluidyne heat exchanger
    Bosche water pump
    Canton Ice box
    Steeda pulley tensioner
    BMR Tubular K-Member
    Steeda 10rib belt drive (11-13psi)
    Fuel System:
    63# Injectors
    Ford GT dual fuel pumps
    Exhaust:
    Mac axlebacks
    Mac Prochamber midpipe
    BBK LT headers
    Custom midpipe connectors
    Suspension:
    BMR Lower control arms
    BMR LCA relocation brackets
    BMR adj. Pan-hard bar
    Eibach Pro kit
    Tokico D-specs
    Drive-train:
    TR6060
    Shelby shifter/black ball
    Spec 3+ Clutch
    Coast 1 pc. Al Drive-shaft
    8.8 rear with 4:10 FRPP gears
    CHE Driveshaft loop
    Wheels+Tires:
    Saleen replicas 18x9, 18x10
    BFGoodrich gForce KDW 245/40/18 and 265/35/18
    M/T ET Streets 26x11.5x17
    Misc.:
    SOS triple Gauge pod
    Autometer Fuel pressure gauge
    Autometer Boost gauge
    AEM Wideband O2
    XCal2, Procal and Diablo tuners
    N2MB 2-step no lift shift
    Granatelli line locs
    Appearance:
    GT500 Front splitter
    GT500 Rear spoiler
    VIS 2.5" CF Cowl hood
    35% tint front 2
    Limo tint rear 3
    Tinted front signals
    Painted rear Faux gas cap
    Sequential tail lights
    There may be more..
    Here is the engine ready to go in the car
    Here is the motor just after being put into the car
    The car is idling perfectly with the FRPP Whipple 10psi tune. I have not yet drove it and will not until the roads clear up. I'll be getting Eric Brooks to tune it.
    Here is a video of the start up.
    http://www.youtube.com/watch?v=ol2V8LrV90U
    nice.10psi?are you planning on running more once u get it to eric?
    Senior Member Array beefcake's Avatar
    Feb 2003
    cincinnati, oh
    2,765
    Quote Originally Posted by 16yroldcobraboy View Post
    looks good
  6. #4
    Mar 2008
    45
    Ya, I have the Steeda 10 rib belt drive 11-13psi kit. I might even order a smaller pulley for it.
  7. #5
    Member Array klaw's Avatar
    May 2009
    Calgary, Alberta
    78
    Quote Originally Posted by explict View Post
    To increase the boost on the 10-rib, they supply you with a larger crank pulley and longer belt. Upper pulley stays the same.
  8. #6
    Mar 2008
    45
    Quote Originally Posted by klaw View Post
    10-4 didn't know that!! I might call them today...
  9. #7
    Mar 2008
    45
    Got my Eric Brooks tune via E-mail a couple days back. Still waiting on my Injectors that should have been here. Cleaned the car today pretty good!
  10. #8
    Senior Member Array Anthony05GT's Avatar
    Sep 2006
    Northern Harford County Maryland
    1,783
    Looks nice! You've definitely got some clams wrapped up in that. On that 10 rib belt drive...could you measure the distance from the front edge of the 6 rib belt to the front edge of the 10 rib so I can find out how much farther forward the new belt will sit? I'd appreciate that.
  11. #9
    Mar 2008
    45
    There is 1-1/2" separating the belts. From the end of the 6rib to the end of the 10rib is 2-7/8". From the end of the 6rib to the furthest point out on the 10rib (Tensioner sticks out an inch) is 3-7/8"
  12. #10
    Sep 2006
    1,783
    I have about 3'' left to go forward. Take a look at my hood in this pic. The vent in the hood has my stock Whipple pulley 3'' behind the vent sticking up through the lower layer of the hood duct. Looks like I may have to go 8 rib with this hood.
    Thanks for the measurements...I appreciate it. Steeda couldn't tell me over the phone. Gus didn't know.
  13. #11
    Sep 2006
    1,783
    If I understand your description correctly the blower pulley is 3-7/8'' out farther now???
    Just to be sure because I have room for the tensioner to stick out more, just not the blower pulley.
  14. #12
    Mar 2008
    45
    The Blower pulley is sticking out 2 7/8" more than before.
  15. #13
    Man, way to go - nice build up. Look forward to seeing how it runs. Congrats on the build.
  16. #14
    Mar 2008
    45
    Got the tune and injectors in the car today and did an oil change. Still waiting for the throttle body though. I took the car for a drive to see how it was without the throttle-body. It's runs really rich and stalls when I let it out of gear to come to a stop. But I'll see how it is when I get the TB in.
  17. #15
    Mar 2008
    45
    Well I FINALLY got my GT500 TB today. I am going backwards I swear!!!
    Put it on, first thing I noticed is that the fuel line is scrapping off of it. This is due to the taller 60lb injectors. So I bought Fore Precision fuel rails from Lethal! so the fuel intake comes off the front of the rail instead of the top. I can also change the fuel pressure sender location so the intake is not sitting on the sender the way it is now.
    Second problem is that the TB does not fit!!!!!! I will probably try switching the TPS over from the stock one to the GT500 one and see if it works! (Stock one is 1/4"-3/8" narrower!) Anyone done this?
    I also have another project on the go on the inside of the car. But that is for another thread!!!!!!!
  18. Remove Advertisements
Page 1 of 2 12 Last
  1. Aluminator
    By Illmachur1! in forum 2003 - 2004 Mach 1 Mustang
    Last Post: 11-07-2010, 09:53 PM
  2. New guy, GT w/ Aluminator
    By SonicSVT in forum New Member Introductions
    Last Post: 01-15-2010, 11:39 AM
  3. Aluminator? Is this new?
    By 99PanozAIV in forum 1996 - 1998 SVT Mustang Cobra
    Last Post: 07-31-2007, 07:13 PM
  4. How to find out build date and build number
    By T76 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 05-27-2005, 02:51 PM
  5. How to find out build date and build number
    By T76 in forum 2005 - 2010 Mustang GT
    Last Post: 05-27-2005, 06:48 AM
