95 cobra running rough
Results 1 to 5 of 5
    Member Array
    Aug 2009
    colorado springs, co
    55
    Default 95 cobra running rough
    i have a buddy who has a stock 95 cobra with just basic bolt ons. he recently took the intake and intake manifold off to clean out carbon build up out. he put it back together with all new gaskets. he is having a problem with the car idling and when you rev it up it hestitates for a few moments then when you let off the throttle it finally revs and busts up really bad. he has sprayed starter fluid all over the intake to see if the car idles different for a change in idle but no luck. the distributor was not taken off so we dont think its a timing prob. so any inputs would be appreciated thanks guys
    Member Array
    Aug 2009
    55
    changed the tps and it still runs rough and will not rev over 2100 rpm
    Senior Member Array Magic's Avatar
    Apr 2005
    North
    3,286
    check all the electrical connectors, check the vacuum lines etc...
  6. #4
    Slowest Moderator Cobra in the Land Array Slow95Cobra's Avatar
    Jul 2007
    Denton N.C.
    596
    check the PCV valve, and the screen under it. ive seen them clog up and make a 5.0 run like crap. also, unplug the MAF, and see if its better, run it around the block unplugged. if it gets better, may need a MAF, pull it out and check for contanimation on the MAF sensor itself
  7. #5
    Having same problem with my 95 gt im into valve guides now to see if maybe thats it. When u take the oil fill cap off does it suck ur hand down?
  8. Remove Advertisements
  1. Car is running rough !
    By diablogt02 in forum 1996 - 2004 Mustang GT
    Last Post: 07-09-2010, 10:34 PM
  2. 03 Cobra misfiring/running rough- HELP
    By chapmanroost in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 05-25-2010, 09:46 PM
  3. rough running
    By 02ScreamingGT in forum 1996 - 2004 Mustang GT
    Last Post: 11-29-2008, 04:04 PM
  4. rough running
    By 02ScreamingGT in forum Kenne Bell Tech
    Last Post: 11-29-2008, 04:03 PM
