Is Boost Better or Timing Better? - Page 2
Page 2 of 2 First 12
Results 16 to 18 of 18
  1. #16
    Senior Member Array Towelly's Avatar
    Jun 2007
    Eastern Iowa
    737
    What kind of consistency are you seeing?
  3. #17
    I've been seeing anywhere from 80 to 90% alcohol content here in NorthEast Indiana.
  4. #18
    Premium Member Array black2003cobra's Avatar
    Sep 2003
    Rochester, NY
    4,026
    As we all know, boost increases the amount (mass) of air ingested, which means the engine can burn more fuel. Increasing spark timing further towards MBTT on the other hand, improves the so-called, thermal-conversion efficiency of the motor, (which is defined as the amount of work done over the cycle divided by the heat input from the fuel. Don't let anyone tell you that increasing timing closer to MBTT reduces efficiency, BTW. Yes...I've seen it posted.) As a general rule, the energy released by simply burning more fuel is going to "win" over efficiency gains from improved timing, at a given knock limit. That's why one can still make more power by increasing boost, while pulling timing at the same time. Just thought I'd add my thoughts.
  1. More boost or more timing?
    By skaarew04svt in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 07-21-2008, 08:26 PM
  2. boost..or timing???
    By slo-poc in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 08-08-2007, 07:06 AM
  3. Less Timing and More Boost???
    By 01GTvert in forum Turbo Modular
    Last Post: 04-27-2006, 03:15 PM
  4. Timing and boost
    By WUP THIS in forum Tuning and Diagnostics
    Last Post: 01-04-2006, 08:22 AM
Tags for this Thread
