More noise from my KB please!!!
Results 1 to 11 of 11
    Member Array Predator07's Avatar
    Feb 2010
    Troy, Ohio
    31
    Default More noise from my KB please!!!
    Just wondering if there was any good way to get more sound from my 2.6L on my 2007 GT? Short of spinning it faster... I'll be doing that anyway. I figured that opening up the inlet side with a single blade throttle body or something would probably help. It doesnt matter whether it relates to the superchager it self. Or the drive setup.
    I know the KB is a well build unit and was designed to be efficient and quiet. But I know there are a few of us hardcore blower guys out there that would like a little more of that cool KB blower whine.
    Thanks in advance for any incite anyone may have.
    Senior Member Array zipperhead's Avatar
    Jul 2006
    Upstate New york
    171
    My got slightly louder a WOT when I put the mono blade on (stage 2). I picked up about 1.5 psi but ran no faster at the track.
    Senior Member Array GoneFord's Avatar
    Jun 2008
    VA
    454
    I would have liked more whine too, but I haven't heard of anyone turning up the whine except for a few who said increased boost resulted in increased whine.
  6. #4
    Senior Member Array Seraphim38's Avatar
    Apr 2009
    Woodinville, WA
    734
    single blade throttle body. The shorter the intake, the louder it will be. If you get one of the filter mounted to the end of the MAF under the hood dealies, you will get the loudest setup. Also, the lighter the material between the MAF and the intake, the louder it will be.
  7. #5
    Feb 2010
    Troy, Ohio
    31
    I have have to agree. I always thought the same thing. I mean look at the Saleen blower with shaker setup. Its quite a bit louder. But dont let KB know your messing with thier intake setup because it will let in too much underhood heat.
    What I've been wanting to do is an "old school setup". A "shaker type" intake setup with a polished highborne style scoop that will stick through hood. A container of some sort to sit between the scoop and blower that would contain the maf, filter and maybe TB. Either feeding into the inlet of the KB or a custom inlet feeding directly into the rear of compressor from the top.
    I've grown up around the old hotrods and they are still cool today. If this was put together right it should look just as cool. The only thing I havent quite figured out is a way to temporarily keep out water if stuck out in rain. Maybe make the scoop and lower solid but removable and have a pan to seal in the opening in the hood. If anyone has wanted to produce something similar to this or is good at fabing parts let me know.
  8. #6
    Feb 2010
    Troy, Ohio
    31
    What type of air inlet system do you have on yours? It's hard to tell from your signature.
    Quote Originally Posted by Seraphim38 View Post
  9. #7
    Senior Member Array Miracle's Avatar
    Nov 2007
    Clarksville, TN
    110
    Is yours as loud as mine is?
    http://www.youtube.com/watch?v=nqczwWSajXI
  10. #8
    Feb 2010
    Troy, Ohio
    31
    This is one of my first pulls after install. Most of the noise is from the dynojet. You can hear the KB in the upper RPM's though.
    http://s28.photobucket.com/albums/c2...1105130832.flv
  11. #9
    Feb 2010
    Troy, Ohio
    31
    Here is one of my last pulls from last year....
    http://s28.photobucket.com/albums/c2...1117115900.flv
  12. #10
    Senior Member Array HEAVYGT's Avatar
    Feb 2007
    Elgin, IL.
    124
    why do the last two posts fail????
  13. #11
    Feb 2010
    Troy, Ohio
    31
    You mean fail as in why are they not loud enough? I think they come off louder in the video. My full exhaust is loud enough to cover it up.
  14. Remove Advertisements
  1. car noise.....
    By 1raresnake in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 02-08-2009, 08:06 AM
  2. What is this noise?
    By acreature in forum 2003 - 2004 Mach 1 Mustang
    Last Post: 07-21-2007, 06:36 PM
  3. New Noise :(
    By udelose in forum 2005 - 2010 Mustang GT
    Last Post: 04-02-2007, 09:57 AM
  4. Name that noise...
    By 03yllwguy in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 09-15-2006, 11:59 AM
Tags for this Thread
