2003 DSG Cobra **Twin Turbo** 1018rwhp
Page 1 of 2 12 Last
Results 1 to 15 of 17
    Senior Member Array RAZRS EDGE's Avatar
    Oct 2004
    Oklahoma City, OK
    765
    Icon2 2003 DSG Cobra **Twin Turbo** 1018rwhp
    Well, the time has come to move on. I never thought this day would come but I have a bad itch for a new project. The 03’-04’ Cobras have been my home for the last 7 years but it’s time for a change. The car is for sale; just testing the waters to see if someone wants her.
    I purchased this car from a fellow SVTP member in January of 2007 after my Black 2004 was stolen the month before. At the time of purchase, it had 17k miles on it with a stock engine in her. As you can see from the mileage, she has not been a daily driver. Could EASILY be but I’m too anal in keeping things clean. Plus, it’s nice to have a 2nd car that you know you can look forward to on the weekends or a cruise after work during the week.
    This car is an animal. The power comes on very hard. 3rd and 4th pull like there is no tomorrow. Wish I had some track times for this setup but I do not. It runs great for a 6-speed car and it would be euphoric with an auto swap.
    A lot of blood, sweat and tears have gone into this car. It’s my pride and joy but it’s time for someone else to enjoy it as much as I have. You couldn’t replicate this car for anywhere near what I’m asking for it. I completely understand you never get your money back in something like this and I don’t anticipate coming close. My asking price is cheap for the amount of time, care and parts that have gone into this car. Anyone that knows me can testify for the amount of care and love that goes into my cars. If it’s worth doing, it’s worth doing right.
    2003 Mustang Cobra
    Dark Shadow Grey
    27,513 miles on the body
    Less than 1500 on the engine
    Custom Tuned by Manny @ HPP Racing w/ SCT software
    1018 RWHP / 918 RWTQ @ 24psi on C16
    $37k takes her home
    Car is paid for and has a clear title. Feel free to PM with any questions or call my cell @ 405-207-7737
    I will post dyno sheets tomorrow once I scan them. They are in frames at the moment.
    322ci Engine:
    Sleeved Aluminum Teksid Block
    3.75“ Stroke
    3.70” Bore
    9.0:1 Compression
    Oliver Billet I-Beam Rods
    JE Pistons
    Clevite Race Bearings
    Total Seal Piston Rings
    Ported/Polished/Surfaced Factory Heads
    Stock Combustion Chambers
    5-angle Valve job
    Stainless 0.5mm Oversized Valves
    HPP Billet Cams(blower grind, still has more potential w/ friendlier Turbo grind)
    Innovators West Harmonic Dampner
    200 amp HO Alternator
    Head Cooling Mod
    ALL NEW Ford Racing front timing set (cam gears, timing chains, tensioners and bolts; less than 300 miles since all of that was replaced)
    All ARP Hardware
    Moroso Breather/Catch-can
    New OEM starter (replaced 2 months ago)
    HPP Twin Turbo System:
    (2) Precision T4 61mm Ball-bearing Turbochargers
    Turbine Housing Heat Blankets
    HPP Sheet metal Upper Intake
    Sullivan Lower Intake
    LFP Single-blade Throttlebody
    (2) Tial 38 MM Wastegates
    Tial 50mm Blowoff Valve
    Front-mount air-to-air Intercooler
    E-Boost 2 Electronic Boost Controller
    Custom 4” Aluminum MAF Housing
    Slot Style MAF
    Dual Electric Cut-outs
    Custom Powder coating on Hot and Cold side
    Trunk Mounted Battery
    Front Suspension:
    D&D Tubular K-Member
    Maximum Motorsports Adjustable Coilovers
    Maximum Motorsports Caster-Camber Plates
    Stock Sway bay removed (still have it and will go with car)
    Maximum Motorsports Full Length Subframe Connectors (welded in)
    Transmission:
    26-spline Input Shaft
    Ram Twin Disk Clutch
    New Ford Clutch Cable
    Fore Firewall Cable Adjuster
    Triple hook Quadrant
    Drive-shaft loop
    Steeda Tri-Ax shifter
    IRS:
    DSS Level 5 Half-shafts
    Complete Derlin Bushing Kit
    Solid-mount Aluminum Diff Bushings
    Billetflow Diff Brace
    Stock 3.55 gear ratio
    Fuel System:
    Return Style
    Fore Precision Triple Pump Billet Hat
    (2) Walbro 255 pumps
    Sullivan fuel Rails
    Ford Racing 80lb Injectors
    Kenne Bell Boost-A-Pump
    Interior:
    Stock Front and Rear Seats
    No cage/roll bar (although it could definitely use one)
    Speed of Sound Dual Gauge Pod
    Autometer Fuel Pressure gauge
    AEM Wideband
    E-Boost 2 Boost controller mounted on steering column
    Raptor Shift-light mounted in A/C vent
    Pioneer D3 Navigation System w/ iPod cable in center console
    Electric Cutout switch mounted next to shifter
    Wheels & Tires:
    Front: AFS 18” narrowed to 4” wide (sleeper!)
    Rear: AFS 18” x 10.5”
    M&H 325/40/18 Drag Radial (28.2” tall)
    3/8” Wheel Spacers
    Oct 2004
    Oklahoma City, OK
    765
    I'm open to any reasonable offers as well!
    Senior Member Array Shaun03gt's Avatar
    Jun 2010
    MA
    223
    Awesome car man, beutiful. GLWS
  6. #4
    Senior Member Array JetmechF16's Avatar
    Feb 2007
    Texas!
    255
    That is THE most beautiful TT cobra i've ever seen. Wish I had the money!!
  7. #5
    Senior Member Array
    Nov 2007
    Naples, Florida
    142
    I'm doing everything I can right now to sell my car... so I can buy yours!
    So you should help me out and then we'll both be happy!
  8. #6
    Senior Member Array hj16's Avatar
    Aug 2003
    Chicago, IL
    1,650
    Stunning... what a beast
  9. #7
    maybe interested in a 06 custom zx14 with mods an 4k miles
  10. #8
    Oct 2004
    Oklahoma City, OK
    765
    Thanks for the kind words everyone!
    Quote Originally Posted by injektdsnake03 View Post
    No trades. Thank you!
  11. #9
    kool man no prob, glws i hav a single turbo auto dsg car an the color is awesome u hav a beautiful car bro
  12. #10
    doing it with a 2v.. Array blackonblacksls's Avatar
    Sep 2006
    houston, texas
    2,589
    seen this at Tx2K10 i think, looks pretty badass in person.
  13. #11
    Still no trades at all?
    Have a lot to trade
  14. #12
    Oct 2004
    Oklahoma City, OK
    765
    Only car I'm looking to get into is a C6 Z06 or a Viper. If you have either send me a PM
  15. #13
    Quote Originally Posted by RAZRS EDGE View Post
    Have both. Sending PM now
  16. #14
    Oct 2004
    Oklahoma City, OK
    765
    Quote Originally Posted by twinvipers View Post
    Pm replied!
  17. #15
    Oct 2004
    Oklahoma City, OK
    765
    Bump!
  18. Remove Advertisements
Page 1 of 2 12 Last
  1. 2003 Twin Turbo Cobra DSG
    By cobrat2003 in forum Vehicles
    Last Post: 03-05-2010, 09:49 PM
  2. 2003 Black Twin Turbo Cobra
    By TTBEAST in forum Vehicles
    Last Post: 08-26-2009, 10:42 PM
  3. 2003 Black Twin Turbo Cobra
    Last Post: 08-03-2009, 04:45 PM
  4. Selling 2003 Twin Turbo Cobra
    By 2003Slobra in forum Vehicles
    Last Post: 08-01-2009, 04:04 PM
  5. Replies: 19
    Last Post: 08-13-2005, 09:55 AM
Tags for this Thread
