GT500 Fuel Rail Photoshoot!!!
Results 1 to 2 of 2
    Senior Member Array
    Jan 2009
    Raleigh NC
    416
    Default GT500 Fuel Rail Photoshoot!!!
    GT500 Fuel Rails!!!
    <The Ultimate Fuel Rail Kit Available Now>
    GT500 Fuel Rails
    The Fore Precision Works GT500 High Flow Fuel Rails are designed to accommodate the return and return-less style fuel system configuration. These high flowing billet fuel rails are designed as the ONLY full billet ‘one piece’ fuel rail to allow fully functional ratings (no extrusions).
    Fuel Rails $330
    Fore Precision Stock Fuel Line Adapter Kits
    Now available through us directly or your favorite Fore Precision dealer
    Everything you will need to upgrade to Fore Precision fuel rails--and still use stock fuel lines!
    The 2007-2010 GT500 kit contains:
    Fore Precision Stock Line Adapter (with 1/8 NPT port)
    Fore Precision -8AN o-ring plug
    Aeroquip Startlite crossover line (approved by NASCAR, NHRA, IHRA)
    two 90° forged o-ring fittings
    two straight reusable hose ends
    Stay Tuned for MORE from FORE!!!
    Fuel Rail Kit $149
    Add ons from Fore include: S197 GT500 Stock Fuel Line Adapter (as seen below),
    AN-8 End Fittings, 1/8th NPT plugs, spacers, and more.....
    Check it out on the latest MMFF or 5.0 Magazine in stores now!
    "Muscle Mustangs & Fast Fords Blog"
    Need to use BIG injectors?
    Fore Precision GT500 Rail Spacers raise our rails to accommodate
    standard length injectors, such as the 80 lb/hour injectors from Ford Racing. Our spacers are contoured to blend our sleek rails to the factory intake manifold for a perfect fit and finish.
    Check them out at Fore Precision Works!!!
    Senior Member Array
    Jan 2009
    Raleigh NC
    416
    In stock!
  4. Remove Advertisements
  1. GT500 fuel rail size and HP limit?
    By Slo05gt in forum 2007 - 2014 Shelby GT500 Mustang
    Last Post: 03-24-2008, 10:59 PM
  2. GT500 Photoshoot **56K Warning**
    By 01SteedaGT in forum Pictures and Videos
    Last Post: 10-27-2007, 07:49 PM
  3. Return style fuel system and Fuel Rail pressure sensor...
    By justin03 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 04-17-2005, 08:26 AM
  4. Replies: 4
    Last Post: 12-22-2004, 01:49 PM
  5. Fuel rail testport fitting size for fuel solenoid supply?
    By broke7 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 06-25-2004, 12:27 AM
Tags for this Thread
