"Y Block" IT!!!!
Results 1 to 2 of 2
    Senior Member Array
    Jan 2009
    Raleigh NC
    416
    Default "Y Block" IT!!!!
    Fore Precision Works offers
    Y Blocks!
    When adding upgraded fuel lines to your fuel system,
    you need a quality product that offers reliability and strength.
    Demand Fore Precision!!!
    -CNC machined out of high quality billet aluminum.
    -Manufactured with the least amount of interior angles to offer maximum flow and cleanest hose routing.
    -Offered with or without fittings to suit your configuration.
    3 into 1 Y-Blocks
    The Fore Precision 3-into-1 Y-Block is used for many applications such as the FPW Triple Fuel Hat.
    List Price: $ 58.00
    2 into 1 Y-Blocks
    The Fore Precision 2-into-1 Y-Block is used for many applications including and not limited too the FPW Dual Fuel Hat, Regulator, and Fuel Rails.
    List Price: $ 48.00
    The "Nickel" Y-Blocks are available!
    The Coating is used in ethanol applications for added protection against corrosion. The Coating is available in any of our full billet aluminum fuel products.
    http://www.foreprecisionworks.com
    All of our products are conceived, developed, and manufactured at our facility in North Carolina. Every product of our business reflects engineering and manufacturing excellence.
    Senior Member Array
    Jan 2009
    Raleigh NC
    416
    The 3-1 Y BLOCK is manufactured with the least amount of interior angles to offer maximum flow and the cleanest hose routing.
    Port configuration:
    Three 1/4 NPT (pipe thread) typically used with AN-6 fitting
    Single 1/2 NPT (pipe thread) typically used with AN-8 through AN-12 fitting
    The 2-1 Y Block is machined from solid 6061 billet aluminum with parallel outlets enabling the cleanest hose routing available.
    Port configuration:
    Three 3/8 NPT (pipe thread) typically used with AN-8 fitting
  4. Remove Advertisements
  1. aluminum modular 5.0 block the "cammer"
    By 97 bulls in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 01-16-2011, 10:14 PM
  2. New in box Aluminum 2v "mountain"block
    By '00 hi-po in forum Engine Parts
    Last Post: 02-05-2010, 06:37 PM
  3. Help with water tube "aluminum block"
    By ls1hater in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 06-01-2007, 02:46 PM
  4. 4.6 Aluminum "Mountain" Block has arrived!
    By DSG Mach ONE in forum 1996 - 1998 SVT Mustang Cobra
    Last Post: 03-24-2005, 09:36 PM
Tags for this Thread
