Wiper motor issue
Results 1 to 6 of 6
    Member Array
    Jun 2009
    Thomasville, NC
    34
    Default Wiper motor issue
    Just wondering if anyone has run into any clearence issues with the wiper motor and the hydroboost assembly. I'm using a hydroboost unit and lines from the 99 up gt cars assuming there all the same. Wiper motor hits the hydroboost lines.
    Thanks
    Justin
    Any Pics?
    I had the same issue. I'm running a '01 hyroboost. I ended up just tweeking the lines a little so they would clear.
  6. #4
    Member Array
    Jun 2009
    Thomasville, NC
    34
    Haven't had any chances to get pics of the issue yet. Did you just bend yours out of the way. The one closest to the fender i was able to bend enough to get by but the other one is so short i am afraid i will kink it.
  7. #5
    I bent it close to the fitting. It helps if you loosen the wiper motor to move it up a little, then install the hydroboost. I'll try and snap a pic this afternoon.
  8. #6
    Senior Member Array Cobra4Me's Avatar
    Dec 2003
    San Diego, CA.
    396
    I also bent the line a little but I used the Newer 03 wiper motor which helps avoid major interference, here's an image:
  9. Remove Advertisements
  1. motor issue
    By Turbo96cobra in forum 1996 - 1998 SVT Mustang Cobra
    Last Post: 08-24-2012, 01:44 AM
  2. Hydroboost in a fox clearing wiper motor
    By cpurtellII in forum Modular V8 and V10 Conversions and Swaps
    Last Post: 06-14-2011, 12:35 AM
  3. FS: Wiper Motor, Arms, Blades 03 Cobra
    By cChrisM in forum Exterior Parts
    Last Post: 11-07-2009, 05:35 PM
  4. pcv/motor issue
    By dredg0 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 10-20-2008, 09:27 PM
  5. 94-04 Wiper Motor into Fox HELP!
    By SVT32VDOHC in forum Modular V8 and V10 Conversions and Swaps
    Last Post: 01-11-2008, 08:27 AM
