Whipple 3.4 and Eaton Swap Kit
Results 1 to 7 of 7
    Senior Member Array Bill Putnam's Avatar
    Jan 2003
    Wellington, FL
    289
    Default Whipple 3.4 and Eaton Swap Kit
    I’m going a different route with my car and before I break up all the pieces I figured I’d list the entire kit here for a week or two. The kit below is a near complete setup to install a Whipple 3.4 on your Mach 1. I had this on my car and running with all the pieces below. With the 3.5 pulley on E85 it should have easily been good for mid 700RWHP. However due to bottom end problems I never got any full pulls with it. The Whipple and other parts listed as like new have 110 street miles and about 5-6 hours of dyno time on them. The rest are all stock 03/04 Cobra parts or aftermarket upgrades I bought for the original Eaton swap I did last year. Price is $6000 plus shipping for everything.
    Whipple 3.4 with 3.50” and 4.00” pulleys (like new)
    Accufab single blade throttle body polished (like new)
    Fore Precision Fuel rails (like new)
    Lower Intake
    Intercooler
    Intercooler Adapter *
    Crossover Tube *
    Idler Pulley/Bracket*
    Pulley Bridge * with Pulleys and UPR Billet Tensioner
    Billetflow Auxillary idler (not needed for 4.00” pulley)
    Timing Cover with tensioner and pulleys
    Balancer
    Crank Pulley/Cage
    Upper and Lower Alternator Bracket
    Alternator
    AFCO Dual Pass Heat Exchanger
    Heat Exchanger Brackets
    Canton Intercooler Reservoir fits in stock battery location (like new)
    Intercooler pump (new)
    Intercooler pump mounting bracket
    Intercooler pump pigtail
    Intercooler lines (not factory but what I used to plumb the system)
    Oil cooler adapter
    Oil cooler (Like new)
    Radiator hoses (like new)
    Intake Tube
    Throttle cable (like new)
    Cruise control cable (like new)
    Belt for 4.00” pulley (like new)
    EGR delete
    IAT2 sensor (like new)
    IAC valve (like new)
    * Items with * next to them are painted black hammered tone.
    What this kit does not include…
    Thermostat housing (same as stock Mach 1)
    Injectors
    IAT2 and Alternator Plug ends
    Power steering reservoir/bracket
    Vacuum lines
    Fuel rail pressure sensor (same as stock Mach 1)
    Mass air meter
    Air filter
    Emissions related sensors
    Gaskets
    Jan 2003
    Wellington, FL
    289
    The price on the Eaton Swap only parts is $2200 plus shipping.
    Jan 2003
    Wellington, FL
    289
    The Eaton Swap is broken up so here is the individual parts pricing.
    *Whipple 3.4 Gen 2 Black with 3.50” and 4.00” pulleys (like new), Accufab single blade throttle body polished (like new), Fore Precision Fuel
    Rails (clear anodized w/FPRS adapter (like new), EGR Delete, throttle cable bracket, original mounting hardware, does not include bracket for emissions sensors $3900 shipped.
    Eaton Swap Parts (pricing includes shipping and I will combine shipping where possible)
    * 03/04 Cobra Lower Intake...$315
    * 03/04 Cobra Intercooler...$300
    * 03/04 Cobra Intercooler Adapter (with bolts/gasket)...$80
    * 03/04 Cobra Crossover Tube...$65
    * 03/04 Cobra Alternator (new from Ford)...$175
    * AFCO Dual Pass Heat Exchanger...$200
    * 03/04 Cobra Heat Exchanger Brackets...$75
    * Canton Intercooler Reservoir fits in stock battery location (like new)...$125
    * 03/04 Cobra Intercooler pump (new)...$95
    * 03/04 Cobra Intercooler pump mounting bracket...$30
    * 03/04 Cobra Intercooler pump pigtail...$5
    * 03/04 Cobra Oil cooler adapter (Like new)...$50
    * 03/04 Cobra Oil cooler (Like new)...$150
    * 03/04 Cobra Radiator hoses (4 lower hoses)(like new)...$40
    * 03/04 Cobra Intake Tube...$40
    * 03/04 Cobra Throttle cable (like new)...$45
    * 03/04 Cobra Cruise control cable (like new)...$25
  6. #4
    Jan 2003
    Wellington, FL
    289
    SOLD
  7. #5
    Jan 2003
    Wellington, FL
    289
    SOLD
  8. #6
    Jan 2003
    Wellington, FL
    289
    Whipple 3.4 SOLD.
  9. #7
    Senior Member Array
    Apr 2003
    South Florida
    1,686
    Uh oh........
    Look out now....................
  10. Remove Advertisements
  1. F/S parts for Eaton Swap/Whipple 3.4L
    By Stock4VGT in forum Engine Parts
    Last Post: 10-26-2010, 02:16 PM
  2. Whipple 3.4 and Eaton Swap Kit
    By Bill Putnam in forum Power Adders
    Last Post: 08-17-2010, 12:00 PM
  3. fs: eaton swap complete, and 2.3 whipple
    By Blownnotcher in forum Power Adders
    Last Post: 02-12-2010, 06:12 PM
  4. Eaton Swap parts - Whipple, Metco, etc.
    By AMD[H]unter in forum Engine Parts
    Last Post: 10-30-2009, 01:46 PM
  5. Complete Eaton Swap/2.3L Whipple + More!
    By SIrRicCuS in forum Power Adders
    Last Post: 07-25-2009, 01:01 PM
