Any Boss motor builds? - Page 2
Page 2 of 2 First 12
Results 16 to 28 of 28
  1. #16
    yeah, that dumb ass 5.0. they are so weak with up to 444hp.
  3. #17
    Banned Array
    Sep 2011
    delaware
    61
    i never said weak did i? i said dumb ass 5.0. i will hold to my statement. ford should have just stuck the 6.2 in the mustang instead of the 5.0, cheaper, more efficient for the weight and it is really cost effective for both superduty and mustang. and ford should have just made a 5.8 for the F150 cuz quite honestly i miss my 5.4. my 2011 F150 5.0 just doesnt pull my boat like my 5.4 3V did. it would be real nice to have an engine for the mustang and/or F150 with atleast a bore size of 3.900 not 3.700, (3.900x3.550=348ci) i look at it this way the 3v and 4v heads only adressed the issue not fix it, these engines are still at a disadvantage! bores too small. there is no need for a 3v or 4v head. but its nice to have less cam lift with a 4v head and make more power than a 2v head, but this issue could have been avoided in the first place with bigger bores. simple as that. a motor will make more power and torque with a 3.900 bore than a engine from 3.700 from either a 2v 3v or a 4v head comparable, and still be more efficient remember the mustang weights in around 3.850lbs and it only has 305ci imagine that car with a 348 or a 6.2?
  4. #18
    from what I hear the 6.2 is a hefty motor. very bulky, too. if the mustang were to use this "workhorse" engine, performance, especially handling would suffer. if you need more power, it is available with the 5.8 super charged engine, now at 650hp in the GT500, and shelby will make more if you want it. I believe the bore is now 93.5 or94mm I have seen it listed both ways. either way it comes out to around 3.7 inches with a stroke of 4.165. yeah, this is not ideal for a high revving motor, but honda motors with vtec rev like crazy with undersquare dimensions.
  6. #19
    Banned Array
    Sep 2011
    delaware
    61
    im aware of the new 5.8 motor but in reality how many people are going to be able to afford an overpriced GT500? (basically fords fault) in the real world the 5.0 is still at a disadvantage, ford should have just made a completely new motor with bigger bores for the mustang and F150. it would be nice to see N/A engines that make nice power and still be streetable but until ford rectifies this issue were going to see more supercharged and turboed mustangs yet again. yippee!! i never said anything about a high revving motor, i mean what good does it do if my engine makes power at high rpm and its only a street motor?
  7. #20
    I hope you build an awesome 6.2L Boss! I'd like to see people push the envelope with this engine.
  8. #21
    Banned Array
    Sep 2011
    delaware
    61
    thanks. i already bought the short block and bare heads with timing chain cover for 4350. my 3 problems are 1. oil pan, 2. stand alone computer 3. intake man. me and my dad will be fabricating a manifold for the 6.2 that wont be the issue, but my serious problem is a computer.
  9. #22
    Geology and Cars Array BlueBossS197's Avatar
    Oct 2006
    Oklahoma
    1,650
    Quote Originally Posted by American Steel View Post
    Motec is your answer. It has provisions for VCT and the dual spark setup you are going to deal with. It also has provisions for up to 8 individual O2 sensors for each exhaust runner. I looked into it specifically for this swap and have been told the Paul's High Performance swapped car is running motec.
  10. #23
    Banned Array
    Sep 2011
    delaware
    61
    you got a pic for this car? thanks for the info
  11. #24
    Oct 2006
    Oklahoma
    1,650
Size:  89.9 KBName:  6.2l_2.jpg
Size:  75.5 KBIt appears as if PHP actually used a Ford ecu somehow. It must have been someone else using the Motec system. All I know is when I eventually undertake this project, it will have a Motec or Bosch system in it.
  12. #25
    Banned Array
    Sep 2011
    delaware
    61
    thanks man. looks kinda roomy in that stang
  13. #26
    Oct 2006
    Oklahoma
    1,650
    Roomy enough that Ford should have put an aluminum 6.2 in the 2013 GT500.
  14. #27
    Banned Array
    Sep 2011
    delaware
    61
    yup exactly
  15. #28
    Banned Array
    Sep 2011
    delaware
    61
    do you have a site link for this car?
  16. Remove Advertisements
  1. FS: Boss 330 5.4 3 Valve Built Motor
    By whiteonwhite350 in forum Engine Parts
    Last Post: 04-02-2010, 10:29 PM
  2. Will Ford develop a DOHC Boss motor
    By JROC in forum 2010 - 2013 F150 SVT Raptor
    Last Post: 09-21-2009, 01:15 PM
  3. Ford Boss Stoker motor?
    By 03yllwcobra in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 04-23-2008, 07:47 AM
  4. Hurricane/Boss motor spy shots in MM/FF!!!!
    By BlueBossS197 in forum 2010 - 2013 F150 SVT Raptor
    Last Post: 02-15-2008, 02:58 PM
  5. Pics of my new Motor built by Boss 330 Racing
    By 169stang in forum 2005 - 2010 Mustang GT
    Last Post: 04-28-2006, 07:44 AM
