Sounds like an exhaust leak but it's not - Page 2
Page 2 of 2 First 12
Results 16 to 20 of 20
  1. #16
    Moderator Array
    Jul 2005
    Hanover Twp. PA
    2,630
    Do you hear it at idle or only part throttle?
    Here is a video of my motor right after being installed, you can hear a ticking at 1 min and on in the video. It is the injectors and followers singing, totally normal.
  3. #17
    Only under throttle while driving. I cannot hear it while idling or revving up the engine listening under the hood.
  4. #18
    Kenne Bell Array Matt@KB's Avatar
    Oct 2010
    Rancho Cucamonga
    95
    How much oil did you put inside the supercharger? Where did it measure on the dipstick? Have you checked the oil since the install? Have you removed the belt and spin the supercharger by hand, if you have do you feel any tight spots or play? Did the manifold sit down on the heads correctly with no wobble? Do you have the knock sensor bosses on your block, if so did you trim them down to fit the manifold?
  6. #19
    i know this thread is a little old, but i am pulling my hair out with the same problem on my 2000 superchareged saleen. i smoked the exhaust found no leaks, took my x pipe off like 10 times,i did a compresion test on the cylanders thinking it was a bad valve, it is a brand new motor, cant seem to find out what it is. the leak sound is only coming from the left side under a load and is inside the exhaust. im thinking about getting long tube headers but if that doesnt fix it i might burn it to the ground, it is a noise that eats at my ears i dont even want to drive it. someone please help me out
  7. #20
    Its the fuel injectors. Unplug them one by one and you will find the noisy one.
  8. Remove Advertisements
  1. sounds like and exhuast leak but its not?
    By BadMoFo in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 08-07-2006, 02:40 PM
  2. O/R X-pipe install, now sounds like exhaust leak
    By mrpositraction in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 03-04-2006, 08:04 PM
  3. Exhaust Sounds
    By camunaro2000 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 04-25-2005, 10:47 AM
  4. Got the exhaust all up, it sounds GREAT
    By Shanezam203 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 11-04-2004, 07:09 PM
  5. Anyone have sounds/video of QMP exhaust?
    By SVTVenom in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 01-08-2003, 09:17 PM
