tuned for X but no X
Results 1 to 8 of 8
    Default tuned for X but no X
    so i am tuned for an offroad x-pipe but i am having problems with my x-pipe right now so i had to take it off. is it ok to run the tune (which is tuned for OR-X) on my car but run the stock cats and h-pipe?
    im going on a long trip this weekend and am wondering if it will be ok?
    Should be fine. I ran mine like that for a while. I think all the tune does is turn off the rear o2s.
    Whats wrong with your xpipe? Leaking?
    yeah its got a leak, right up by the flange where it mounts to the header.
  6. #4
    see how the actual pipe comes up out of the flange. i didnt think this would cause a problem but sure enough it did.
  7. #5
    good flange: see how the pipe is sunk underneath the flange
  8. #6
    Senior Member Array Bad Intention's Avatar
    Feb 2010
    NAWLINS
    994
    As stated by fiveoh most all tunes come witb back O2's turned off. If you have die grinder or dremel you should be able to trim the overhang out from inside flange.
  9. #7
    yeah, thats the plan, just grind it down...i just dont have the time to get it filed down and put back on the car before i have to leave for the weekend.
    i also got some washers to put on each side of the flange too and brand new gaskets as well, im making sure i dont have to take this off again. even though i am getting pretty good at it.
  10. #8
    Senior Member Array
    Sep 2004
    FH, AZ
    101
    Are the fuel tables at all different in a tune for cats vs no cats??? So will it mess with the AFR?
    I am catless right now but am thinking about getting a catted midpipe to tone down my setup a bit and was wondering if I'd have to get a new tune.
  11. Remove Advertisements
  1. E85 tuned!!
    By jbt930 in forum E85, Ethanol, Methanol and other Alcohol Alternate Fuels
    Last Post: 10-23-2010, 01:19 PM
  2. Just Got My 95 Gt Tuned W/ 408 & F1-r
    By icestang in forum 1996 - 2004 Mustang GT
    Last Post: 11-03-2008, 09:15 PM
  3. Getting tuned!
    By vertigyn in forum 2003 - 2004 Mach 1 Mustang
    Last Post: 06-09-2007, 11:29 PM
  4. KB 2.6 is on and tuned.....
    By 2veloce in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 10-23-2006, 11:29 AM
  5. JLT CAI = Do I need to get the car re-tuned?
    By WikedCobra in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 11-11-2005, 09:53 AM
