5.4L DOHC Steel Timing Chain Guide Kits
Results 1 to 6 of 6
    Default 5.4L DOHC Steel Timing Chain Guide Kits
    SO anyway, as most of the modular engine owners know the factory plastic timing chain guides wear out quite quickly in the 03-04 engines( at least in Australia they did) i was told by my local ford dealer that the fixing kit for the tensioner noise on start up has steel tensioner guides and costs about $800AUD. i did find an aftermarket company in the states who made them, but at the time i had a brain fart and did not bookmark them.
    Soooooooo, i would like to know if anyone here knows who makes the the "steel tensioner guide 5.4L dohc timing kits", as i will be doing the fix after i have finished paying for the car and fitting some bigger heads/cams while the front of the engine is pulled apart anyway. as i feel F.I is being lazy N.A FTW(in about 5 years :*{)
    also does anyone know of any companies who do stroker rotating assemblies for the 5.4, i've seen short/long blocks but no actual assembly kits for the 5.4's.
    Thank you in advance to those who can point me in the right direction
    Cheers, Big Joe
    any takers???? at all???? or is it that i missheard information along the way
    Moving on up... Array Smokin04's Avatar
    Mar 2005
    Goldsboro NC
    4,775
    I have heard of steel tensioners, but not guides. I would think that would make quite the awful racket when running...
  6. #4
    yeah i was most definitely hearing teh information wrong, it WAS steel tensioners NOT steel guides. but now i'm having trouble finding kits that have adjustable cam sprockets for the 5.4's hopefully cloye's will be able to clear things up for me with their products.
  7. #5
    Junior Member Array mystro3vm's Avatar
    Jan 2013
    nsw australia
    15
    I bought metal ratchet tensioners off ebay cns auto i think .unsure about secondary tensioners as I have a 3v. Look up freedom racing for guides,summit racing,cjpony parts, rock auto,maybe amazon hope it helps
    - - - Updated - - -
    Those sites all post to Aussie and give post quotes
  8. #6
    Jan 2013
    nsw australia
    15
    Mmr has adjustable cam gears and post to Aussie aswell
  9. Remove Advertisements
  1. Timing Chain and Guide Kit 4V
    By 97novi2k in forum Engine Parts
    Last Post: 11-14-2009, 07:07 PM
  2. Timing Chain Kits -which one do you use?
    By Parker Lewis in forum 1996 - 2004 Mustang GT
    Last Post: 03-04-2009, 08:40 PM
  3. 2V Timing chain kits
    By BLK GT in forum 1996 - 2004 Mustang GT
    Last Post: 03-02-2009, 08:57 AM
  4. Timing Chain Guide Wear Question
    By Screamn03 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 10-09-2006, 01:28 PM
  5. Need Help With Dohc Chain Tensioner Guide
    By BLUE85GT in forum 1999 - 2001 SVT Mustang Cobra
    Last Post: 12-13-2005, 12:01 PM
