"Look here for threads with key information for owners of 96-98 Mustang Cobras"
This thread was done to keep the sticky'd threads to a minimum and to provide a resource of good tech threads.
This thread will remain locked to keep all posting in the threads themselves and to keep this thread as
organized as possible. If you wish to discuss this TOC or any other ideas for this forum then please feel free to do so in the New Table of Contents thread, your input is valuable to us. If you have a thread that you'd like to be added to the list or a thread that you don't feel should be here, please contact me via PM.
Feel free to post in a thread if it's relevant to what it is you're looking for, no matter how old the thread. The more tech information we have in one place the better.
General
*Engine Builders Resource*
*Offical 4v N/A HP/TRQ List*
"How to Build Max Performance 4.6L Ford Engines" ISBN#188408978X
Eliminate Oil in Your Intake ~ Valve Cover Baffle Mod
Bottom-End
Stock Bottom End Strength
Teskid Block Terminator (03/04 Cobra) Swap Info
Block
Iron vs Aluminum Block Debate
How to ID a Teskid Block (96-98 Cobra[some99], 93-97 MarkVIII)
Crank
Cast Crank Strength
Turning a Steel Crank
5.4 Forged Crank Strength
Rod
Strongest Modular Rod
'03 Cobra Connecting Rods
General Rod Tech via Hot Rod
Piston
'03/04 Cobra Piston Power Rating
'03/04 Cobra Piston ~ Different Grades
Head
*Offical Head Tech Thread*
Port 03+ DOHC Heads?
Cam & Valvetrain
*Offical Cam and Valvetrain Tech Thread*
FR500 Cam Analysis
96-98 Cobra Cam Specs
Solid Lifters Discussion
-Followers thread related to Solid Lifter Discussion
Crower Valvespring Thread
Intake/Induction/Fuel
Short Runner Intake ~ Prep to Port Entry (from MD)
Aviator Intake Control of Runner Valves
Fuel Injector Sizing Calculator
Power Adder
99/01 Kenne Bell Q&A
Oiling
Oil Pump Gears and Trigger Wheels
Exhaust
Ignition
Other
K-Member Removal
Crossover Burp Plug Ford Part#
O-Ring Size for Burp Plug
How to Test Your VSS
How to Test Your Speedometer & Tachometer[/SIZE]
Anatomy of a 96 Mustang CCRM[/SIZE]
General
Bottom-End
Block
Crank
Cast Crank Strength
Rod
Piston
Head
Cam & Valvetrain
FR500 Cam Analysis
Power Adder
Oiling
Exhaust
Ignition
Other
K-Member Removal
