Help, complete drop in LOAD during WOT
Page 1 of 2 12 Last
Results 1 to 15 of 22
    Member Array raetza's Avatar
    Mar 2010
    Madison, AL
    96
    Default Help, complete drop in LOAD during WOT
    I've been fighting this nasty little problem for a while and need some help. My car is an 06 Mustang GT with a forged/stroked 3V and a KB 2.6, Comp Cams Stage II Blower cams, 80 lb injectors, return fuel system running E85.
    Problem I'm having is under load doing WOT pulls while tuning my MAF curve, the car suddenly falls off like I let off the throttle. I have logged everything I can think of to find a corresponding event...and nothing. Spark is constant, Throttle angle remains at WOT, A/F is good...as I said it feels as if I let off the throttle ...but didn't. Load suddenly drops like a rock. The only way to recover is to let off the throttle and then get back on it.
    Any ideas anyone?
    Senior Member Array
    Oct 2005
    so cal
    402
    I know when i was trying to get my maf curve that adjusted i was having a similar problem. I was doing the runs in 3rd gear. I did notice the sound of the exhaust changed for a fraction of a second a few times. On the datalog it showed the load decreased (not sure exactly what drops like a rock means) to less then 200%, the spark increased a few times. On the graph it looked like there were a couple of spikes. We figured out to be a slight loss of traction.
    Mar 2010
    Madison, AL
    96
    When I say "Drops like a rock"...I mean the load goes from 1.945 to 0.30 instantaneously...just as if I had completely let off the throttle....but I didn't. When I do let off for a bit and then get back on it...it recovers. TP ABSOLUTE remains constant for the event.
  6. #4
    Could the blower bypass be malfunctioning? Does it happen at the same point every time?
  7. #5
    Mar 2010
    Madison, AL
    96
    Thanks for the input .... I actually had considered disconnecting the bypass and keeping it closed....just for a test. I haven't done that but guess that I will. It actually FEELS like the throttle is closing...but I have logged every PID I can find that has anything to do with throttle and none of them ever show that the throttle is coming off of WOT until far after the drop in Load (when I actually let up).
  8. #6
    Quote Originally Posted by raetza View Post
    Have you adjusted the load with failed maf tables? And on another note what gets scaled for a motor exceeding 1.999 load? Motor size?
  9. #7
    Mar 2010
    Madison, AL
    96
    Thanks for the input....but yes I have modified the load for failed MAF table. Can I log a failed MAF condition?
  10. #8
    Mar 2010
    Madison, AL
    96
    It's not the KB bypass. I tied it shut and the event still occurs. I'm all but convinced that the throttle is being commanded shut and I'm not logging the correct PID to show it....or the correct PID(s) to shed light on why.
  11. #9
    Senior Member Array Vistablue08's Avatar
    Apr 2008
    Maryland
    174
    Have you logged Torque source?
  12. #10
    Oct 2002
    Eastpoint, FL
    19,241
    Check the screenshot for the parameter to see what the PCM is commanding the throttle to do. 82 degrees = WOT
    Email me your tune file and I'll take a peak at it if you want ( eric at brooksspeed dot com)
  13. #11
    Mar 2010
    Madison, AL
    96
    Eric, thanks for the input. I was logging TP ABSOLUTE previously as shown in LOG1. I logged ETC COMMD TA in LOG2. Both events appear to show the throttle position remains WOT until I let off...which is well past the event (loss of LOAD and MAP).
  14. #12
    Mar 2010
    Madison, AL
    96
    @VistaBlue08. I relogged last night with TQ SOURCE and it remains a ZERO for the entire event ... so it doesn't seem to give any hints. Thanks, Alan
  15. #13
    I had this issue with a 2003 Mustang GT. it turned out that there was a problem with the coils, as they all cut loss in power during WOT.
    but the RPM didn't drop to zero as it only dropped to 2rpm and stayed there.
  16. #14
    Mar 2010
    Madison, AL
    96
    Anyone have any fresh ideas for me on this? I was convinced that I had S/C belt slip...but have now discounted this as a possibility. I am fresh out of ideas on what to look for! :(
    Again, for review...I have logged the following:
    1) LOAD and MAP (both inferred) drop suddenly while WOT with a sudden loss of power. Let off of the throttle and get back on it and it goes again for a bit until the same event re-occurs.
    2) SPARK remains constant through the event until LOAD drops, then it increases
    3) No indications that I have logged show the throttle coming off of WOT until I release it (after the power loss)
    4) Injector Pulse Clockticks remain constant until the power loss, at which time they drop
    5) A/F (set currently at 7.4 for high load on E85) go richer than my Wideband will measure (< 6.7) at the time of the power loss
    6) My Boost gauge drops from 15PSI to under 0 instantaneously at the time of the power loss
    7) Airflow through the MAF decreases almost in half at the time of the power loss
    8) Belt is not slipping
    9) Tires are not slipping
    10) KB Bypass is not opening (I tested by tying it shut)
    11) If I remain WOT after the power loss, the car struggles along as you would expect it would with A/F being hugely rich. Boost will NOT return until I let off the throttle for about a second and then stab it again.
    Thanks to anyone with ideas!
  17. #15
    Oct 2002
    Eastpoint, FL
    19,241
    The MAF counts fall resulting in everything else you see. Your boost is going someplace.
  18. Remove Advertisements
Page 1 of 2 12 Last
  1. Fuel pressure drop after WOT.....
    By blowngt in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 08-31-2011, 07:36 PM
  2. return fuel pressure drop under load?
    By Swerve in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 07-10-2010, 04:18 PM
  3. Fuel Pressure drop at WOT on Datalogs
    By TurboOrange in forum 1996 - 2004 Mustang GT
    Last Post: 08-26-2008, 07:19 PM
  4. Voltage drop... WOT triggered???
    By jimmysidecarr in forum Tuning and Diagnostics
    Last Post: 09-06-2005, 08:41 AM
Tags for this Thread
