Timing guide pivot/dowel upgrade
Page 1 of 5 12345 Last
Results 1 to 15 of 69
    Senior Member Array rtusnake's Avatar
    Mar 2005
    Lincoln, AL
    1,569
    Default Timing guide pivot/dowel upgrade
    I have noticed over the past couple years alot of the higher hp modular guys was starting to have problems with the stock timing dowels breaking in the teskid block. Most of them seem to come from spinning and catching traction, putting more of a strain on the timing components. We noticed there is a good bit more material in the block to accept a larger stud. We decided to step the stud size up to a M8x1.25 over the stock 6mm stud. Install is pretty straight forward, just redrilling and tapping the hole for the new stud. These will also work in the wap and iron blocks. Haven't seen as many failures in the iron blocks though. I haven't had my hands on a boss block but they should work if it uses a similar size stock dowel.This a pretty simple part to make if you know someone with a machine shop. We also made several sets if anyone needs some
    The problem
    New stud vs the old
    Few extras
    Do this studs need to be torqued to spec and if so, what are the specs?
    Thanks
    Mar 2005
    Lincoln, AL
    1,569
    I torque them to 12 ft lbs with red loctite
  6. #4
    Iron blocks take dowels. They dont screw in. Atleast on an iron 5.4 they dont.
  7. #5
    Senior Member Array oldmodman's Avatar
    Jul 2003
    West Los Angeles
    1,682
    Quote Originally Posted by rtusnake View Post
    That shouldn't go anywhere.
    And if you ever need to remove it just heat it with a torch.
    I wouldn't mind buying a set for my next build. Since I'm too lazy to make my own.
  8. #6
    Quote Originally Posted by Ironhand View Post
    sure but those dowels are small and they can break as well. You can just remove them and have the hole drilled and tapped for this larger screw in style pivot stud
  9. #7
    Quote Originally Posted by LS1KILR View Post
    Im actually going to making some tool steel pins for mine here soon.
  10. #8
    Mar 2005
    Lincoln, AL
    1,569
    I believe all the iron blocks use press in dowels. I would still go to a larger dowel if you plan to reuse the press in style
  11. #9
    Demented and old Array showme cobra's Avatar
    Dec 2005
    wentzville mo
    5,322
    i just have to say thanks for doing this for all of us, there are quite a large number of builds going on right now and this comes at the right time, the onslaught of great tech on this website has been quite strong lately with great tech threads from you and tony and ed and 03steve
  12. #10
    Mar 2005
    Lincoln, AL
    1,569
    This site is great for tech, most of it exceeds my understanding at times lol.
  13. #11
    Senior Member Array fasteddy03's Avatar
    Jul 2006
    St. Peters, MO
    1,108
    Are there any of these left?
  14. #12
    Mar 2005
    Lincoln, AL
    1,569
    Yeap, several sets made up
  15. #13
    Junior Member Array
    Mar 2013
    Minneota
    1
    Tried to PM but your box must be full.
    Interested in picking up a set.
    Thanks
    Tony [email protected]
  16. #14
    Mar 2005
    Lincoln, AL
    1,569
    Cleaned the inbox some
  17. #15
    ill also take a set!
  18. Remove Advertisements
  1. 5.4L DOHC Steel Timing Chain Guide Kits
    By JOESBOSS in forum 1998 - 2008 Ford Falcon
    Last Post: 01-11-2013, 07:54 PM
  2. Secondary timing chain upgrade
    By Sprayed_Snake03 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 03-23-2012, 11:26 PM
  3. Timing Chain and Guide Kit 4V
    By 97novi2k in forum Engine Parts
    Last Post: 11-14-2009, 06:07 PM
  4. Timing Chain Guide Wear Question
    By Screamn03 in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 10-09-2006, 12:28 PM
  5. correct timing tensioner dowel
    By bigpapa in forum 1999 - 2001 SVT Mustang Cobra
    Last Post: 03-13-2006, 08:14 PM
