Cobra suspension
Results 1 to 2 of 2
    Default Cobra suspension
    I wanted to post this in the 03/04 cobra section because i assume your front suspension setup is similar to the 99 cobra's. I plan on doing a 99 cobra front suspension. I am looking to daily drive this twin turbo 57mm cobra daily. I wanted to know do you think that the K-member from UPR is strong enough to use daily? If not will the stock front end be ok with 800 hp? I am into things handling well since i figure that the straight line performance will not be a problem with that much power. If you guys could chime in that would be great!
    Senior Member Array TJVineyard's Avatar
    Sep 2004
    Austin, TX
    1,390
    If you want to build a car that handles, I would be looking at a K like that built by Maximum Motorsports (and their associated accessories). I'm not sure it will clear your turbo set up, but it was built for that purpose. I think the UPR stuff is designed for weight reduction/straight line performance.
    TJ
  4. Remove Advertisements
  1. 03 cobra suspension FS
    By 02ScreamingGT in forum Suspension Parts
    Last Post: 07-28-2011, 05:14 PM
  2. Some '03 Cobra suspension Parts
    By 357cstang in forum Suspension Parts
    Last Post: 05-17-2009, 09:38 PM
  3. upgrading suspension on '98 Cobra
    By pete3323 in forum 1996 - 1998 SVT Mustang Cobra
    Last Post: 03-03-2008, 04:52 PM
  4. PLEASE HELP 03 Cobra Suspension problem
    By WhyTry 03 in forum Suspension, Handling and Tires Tech
    Last Post: 03-17-2007, 10:07 PM
Tags for this Thread
