E85 Lambda What are you using?
View Poll Results: Forced Induction: What lambda do you use with E85 at wot?
Voters
22. You may not vote on this poll
  • .8 or higher
    5 22.73%
  • .75-.79
    7 31.82%
  • .7-.74
    4 18.18%
  • What's lambda?
    6 27.27%
Results 1 to 7 of 7
    Default E85 Lambda What are you using?
    I've been using a lambda of .8 for E85 at wot with a supercharged motor. Works great. I just spent a few hours researching and finding that the recommended lambda is somewhat richer. I'm also commanding a maximum of 24 degrees spark advance at wot without any spark timing being pulled.
    What are you using and what have you found to work best?
    Premium Member Array black2003cobra's Avatar
    Sep 2003
    Rochester, NY
    4,026
    I don't use it, but I would suspect you'll find 0.8 to 0.83, or so, is probably most typical for FI applications.
    Bruce - I have mine at .79 which is the same I ran on 93 octane. Have wondered if I could go to .80 or .81. I am only commanding 21.x max spark at WOT on a 9.8:1 motor.
  6. #4
    Oct 2002
    Eastpoint, FL
    19,219
    Most common setups I use .8
  7. #5
    Senior Member Array BlownBlu97's Avatar
    Feb 2003
    Cortlandt manor
    5,420
    Fuel A/F conversion chart
  8. #6
    Senior Member Array wickedcobra96's Avatar
    Jul 2008
    NOR CAL
    321
    I set my BS3 up to go for .73 lambda. Which is max Hp for E-85 FI Motors.
  9. #7
    Senior Member Array Turboeverything's Avatar
    Jun 2014
    Iowa City,IA
    124
    My XFI is set to shoot for .8 at lower boost .73 high boost ..
    17* timing
  10. Remove Advertisements
  1. KB 2.2 looking to go E85
    By New Edge in forum E85, Ethanol, Methanol and other Alcohol Alternate Fuels
    Last Post: 02-16-2012, 10:00 PM
  2. Correct lambda for base fuel
    By FordEvangelist in forum Tuning and Diagnostics
    Last Post: 02-12-2012, 05:01 PM
  3. Reasons for 'lazy' lambda recovery?
    By hmwave in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 11-11-2009, 11:50 PM
  4. E85 help!!!! ANYONE.
    By slo4six in forum 1996 - 2004 Mustang GT
    Last Post: 01-07-2008, 03:10 PM
  5. Help convert lambda to A/F ratio??
    By 03SVTCOBRA10TH in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 09-12-2004, 03:19 PM
