Engine Oil
Results 1 to 10 of 10
Thread: Engine Oil
    Member Array
    Oct 2011
    Duncan, Oklahoma
    69
    Default Engine Oil
    I was wondering what engine oil and weight to run in my Mach? I am currently running Royal Purple 5W-20 but I've heard a lot of complaints with Royal Purple. I've also read on a few forums that running a higher weight, like 5W-30, is also better. I haven't had any issues with my car and I change the oil every 3k (currently 26,500 miles on the car) but I am open for suggestions on what other guys are running or reccommend.
    Moderator Array NeverEnuff's Avatar
    Nov 2006
    TX
    3,942
    Run what the oil cap or ownders manual says. Should be 5w-20. I run motorcraft in all my engines. Never a problem thus far.
    I run motorcraft 10w30 @ 101k miles
  6. #4
    Junior Member Array 2002 GT's Avatar
    Jan 2010
    CA
    14
    I use synt Valvoline or Mobile 1 5W-20 everytime no matter if its too cold or hot..
  7. #5
    Nov 2006
    TX
    3,942
    Quote Originally Posted by newedge4vmach1 View Post
    Unless your engine clearances changed, you don't need to run a higher viscosity oil. it could be robbing power from you...stick with what Ford recommends. 5w-20.
  8. #6
    Senior Member Array LITTLEMAGS's Avatar
    Jul 2005
    Ann Arbor, mi
    802
    Quote Originally Posted by NeverEnuff View Post
    exactly
  9. #7
    my engine burns everything else, but 10w30.. needs a rebuild soon so i really dont care what happens.
  10. #8
    Running royal purple 5w 20
  11. #9
    Senior Member Array TOYGT02's Avatar
    Oct 2008
    Virginia Beach
    416
    I've tried a few different oils and weights. I prefer 5w30 Mobil 1 and a motorcraft oil filter
  12. #10
    Senior Member Array cobraracer46's Avatar
    May 2006
    Blue state
    361
    My 2001 Cobra engine is filled with Redline 5W50
  13. Remove Advertisements
  1. Engine oil for oil change ?
    By Old Man in forum 2011 - 2014 Mustang GT and Boss 302
    Last Post: 06-16-2011, 02:48 PM
  2. 4v oil pump in 2v engine - oil pressure?
    By Rickyll7 in forum 1996 - 2004 Mustang GT
    Last Post: 01-17-2011, 11:26 PM
  3. Engine Oil
    By McTeague in forum 2003 - 2004 SVT Mustang Cobra
    Last Post: 12-14-2006, 11:04 AM
  4. engine oil
    By shadow04GT in forum Kenne Bell Tech
    Last Post: 01-14-2005, 11:00 PM
